Keyboard
First post, by The mega-mighty SPP
Hmm.. I wonder how the keyboard input is done in DOSBox. I use a German keymap, and i would appreciate if that would take effect in DOSBox. One important key that i couldn't find (and i tried all keys and combinations, believe me) was the vitally important backslash. So?
Why doesn't the keyboard behave in DOSBox exactly as it does in Windows?
Reply 1 of 5, by Kain
I guess because its emulated to the Hex #s and not to the actual windows ones to be faster.
Athlon Xp 1700+ @ 1.833ghz
ASUS A7N8X v1.4
Crucial 256mb Pc 2100 @ 166 mhz
Chaintech GeForce 4 Ti4200 128mb
Western Digital 40gb WD - 400
Windows 2000 Professional
Creative SB Live! 5.1 Dolby
Maxtop Case w/ 350w PSU
Reply 2 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
As there a almost no games that can handle a german keyboard layout.
so we stick to an english one.
But feel free to use the forwarslash instead
Water flows down the stream
Reply 3 of 5, by questor
Running from BeOS, I experiment the following dosbox keyboard nasties:
1) AltGr-sifted keys work, but they add a "1" to the output
(I.E. in an spanish linuxlike keyboard, "\" is in ALTGR-key-below-esc , but pressing ALTGR-4 to make "\" produces "1\")
2) Of course, I can get vital keystrokes, like "\", using the usa map, as I do when I start a computer from a floppy: "\" is inSHIFT-key_right_of_ L, and so.
3) F3 (copy command line) is implemented, but left, right,F1,F2,F4 DON'T work at command line. So if you want to modify starting part of command line you have to write it over.
4) With some games, direction keys don't work (I¡'m talking about Transarctica/Ice Baron, wich has a text-mode option menu at start that does not recognize arrow keys (but needs them). That game is reported as "supported")
Yes, I've played text-only games on a
Macintosh.
Reply 4 of 5, by eL_PuSHeR
Someone said somewhere else on this forum that a keystroke that's producing an '1' is a feature and not a bug.
showthread.php?s=&threadid=2529
Reply 5 of 5, by questor
Couldn't they have used the standard ANSI code for xtended keypresses? What program DOES use that feature?
(Well, Ms. Office's "Clipo" character is also said to be a feature...)
Macintosh.
