How to install MS-DS6.22 in DOS-BOX
First post, by Floppy
Hello folks,
first post in this forum, i really want to try MS-DOS 6.22 in DOSBOX, i Googled to find this thread in this forum itself: Can I install ms-dos 6.22 inside dosbox? , but no on seems to talk of how to install MS-DOS 6.22.
I would really appreaciate if someone could guide me, is their some kind of cmd line, i h' all the 3 DISK of MS-DOS 6.22 but dont know how, i h' installed it on Virtual Box , but i m considering switshing to DOS-BOS simply because it consums a lot less memory than Virtual Box...
i know a lot of people h' already installed MS-DOS 6.22 , can u please offer some suggestions....
    29.17 KiB
    Scren shot of DOSBOX 0.74 while installing MS-DOS 6.22.
Reply 3 of 26, by Floppy
Hello folks,
thanks for redirecting, although i followed mirekluza exact same method made 10MB with Disk Image Creation Tool, and kept all the there DISK 1,DISK 2,and DISK 3. And kept in a d:\dosbox\ and followed this cmd line.
[code]
mount d: d:\dosbox
imgmount c d:\c.img -size 512,63,16,20 -fs fat
boot -l c [/code]
[B]
STEPS MENTIONED BY mirekluza Do you want to create a floppy disk image or a hard disk image?
Please type hd or fd. [hd] hd
Enter the hard disk size in megabytes, between 1 and 32255
[10]
I will create a hard disk image with
cyl=20
heads=16
sectors per track=63
total sectors=20160
total size=9.84 megabytes
What should I name the image?
[c.img]
Writing: [] Done.
I wrote 10321920 bytes to (null).
The following line should appear in your bochsrc:
ata0-master: type=disk, path="c.img", cylinders=20, heads=16, spt=63
2. I put the HD image (c.img) together with an image of a bootable floppy (msd60.ima) into the directory d:\dosbox on my disc.
3. Then I went on with creating of a patition on the disc. I started DOSBOX with the following lines:
mount d: d:\dosbox
imgmount 2 d:\c.img -size 512,63,16,20 -fs none
boot d:\msd60.ima [/B]
Check the screen shots, how do i boot the DISK 1 from DOSBOX.
Any direction,,,someone who has already installed MS-DOS 6.22.
I would really make a picture TUT regarding Installing MS-DOS 6.22 in DOS-BOX. Hell their are not enough TUT or talks for this, some direction would be great. I cant help myself,since i m not a programmer,,,
But i really want to h' MS-DOS 6.22 is DOSBOX, its something every Windows users must h' since its built around/above DOS,,,and not having MS-DOS any version is at least a must h' for me.
    3.29 KiB
    DISK 1 recognised as DISK~1.ima
    4.61 KiB
    cmd line not working after mounting the c.img
Reply 5 of 26, by Floppy
Well its asking for second disk:
mount d: d:\dosbox
imgmount 2 d:\dosbox\c.img -size 512,63,16,20 -fs none
boot d:\dosbox\disk1~1.ima
First disk booted ,and asks for second disk, entering wont work, so i had to press Ctl+Alt+Del then gave boot d:\dosbox\disk1~2.ima
Its says non-system disks ,press any key to continue...how do i beat that.
Reply 9 of 26, by Floppy
can u please help me here, i dont h' whole night to go through the doc file, i m so close a little friendly gesture is much appreciated.
Yes i m going to use DOS-BOX primarily for dos games and for ms-dos only. i really pressed and running out of ideas.
Thank u:
Reply 12 of 26, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
yes
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 13 of 26, by Floppy
Hey any one installed MS-DOS call me lazy , but even giving this cmd didn't work:
BOOT [diskimg1.img diskimg2.img .. diskimgN.img] [-l driveletter]
First disk booting, 2nd disk wont boot .
    1.72 KiB
Reply 14 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
maybe use file names without tildes
boot works on local files. so you need full names
Water flows down the stream
Reply 16 of 26, by IIGS_User
robertmo wrote:
d:\disk2~1.ima not disk2~1.ima
d:\disk3~1.ima not disk3~1.ima
I see the difference between this and the screenshot above. 😉
Klimawandel.
Reply 17 of 26, by Floppy
The cmd was working ie., BOOT [diskimg1.img diskimg2.img .. diskimgN.img] no need for -l d as described frm the manual:
Maybe it was a blind fluek or just i was lucky, i pressed Ctl + F4 and Alt + F4 and also Shift + F4 randomely and furiously and it then began to install.
May be its a DOSBOX buggy.
However i could not boot to the img file. As described in the TUT ie.,
mount d: d:\dosbox
boot -l c
But i can' tload the MS-DOS it say: missing Operating System:
Now whats with this: How do i load MS-DOS already installed.
    2.98 KiB
Reply 18 of 26, by Floppy
may be this is really stupid question. the above may not be the actual cmd. But i m not able to load or mount that c.img i.e.,ms-dos finished installing but unable to load it.Hope someone understood.. can someone kindly suggest how do i do that. As i said this is the first time i m installing ms-dos on dosbox. i m so close yet so far, any suggestion please.
