Constructor?
First post, by AtlasRapture
I got it to install through dosbox, and sound runs fine but when I try to run it I get a message about it needing the CD in the drive. which it is. I've googled it and apparently it works under Windows 7 with the Windows 95 patch, however for me it does not it just displays a blank screen then eventually quits me back to windows. Any ideas?
Reply 1 of 33, by Qbix
Rank DOSBox Author
DOSBox Author
contstructor works fine in dosbox with the cdrom.
Maybe check the 60 seconds to dosbox guide from the guides forum.
Water flows down the stream
Reply 2 of 33, by AtlasRapture
I followed 'The Newbie's Pictorial Guide To DOSBox' by firestorm225 first, then as you suggested the 60 sec guide and it still asks for a CD? (I'll add that its an legit version of the game as I brought it when it was first released.)
As for system specs, i'm on Windows 7 Home Premium with the latest DOSbox version installed and running.
Graphics is a NVIDIA GeForce 9500 GT, Sound is OnBoard (don't know how to get more info on that.) 4906MB RAM (About 4 GB in total, though Windows only useses about 2-3), AMD Athlon 64 X2 Duel Core Processor 5200+(2CPUs) ~2.7GHz.
Reply 3 of 33, by TeaRex
Can you write down *exactly* what commands you use in DOSBox to mount the game folder and the CD-ROM?
tearex
Reply 4 of 33, by AtlasRapture
All I do is type
mount D: E:\
then run GAME.exe from my mounted C drive. I thought that would be enough but obviously its not.
Reply 6 of 33, by AtlasRapture
I re-read the guide and it seems I had missed the -t cdrom part which obviously you need. Thanks for your help. 😀
Reply 7 of 33, by AtlasRapture
Ok new problem now. The game goes to a blank screen before quitting me back to windows. No error messages or anything. Any ideas?
Reply 8 of 33, by robertmo
what is your dosbox version and where have you got it from?
post content of "DOSBox Status Window" (in Windows: right click on its title bar -> edit)
enclose your dosbox's config file
post your mount lines and what is written under every mount line
post what is written after you type "mount"
Reply 9 of 33, by AtlasRapture
Dosbox version 0.74 from here.
All I managed to notice before it closes (as it closes itself very quickly.) is:
DOSBox version 0.74
Copyright 2002-2010 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file C:\DOSbox\DOSBox-0.74\dosbox.conf
CONFIG:Loading additional settings from config file C:\DOSbox\profiles\5.conf
MIDI:Opened device:win32
DOSBox switched to max cycles, because of the setting: cycles=auto. If the game runs to fast try a fixed cycles amount in DOSBox's options.
I would try adjusting the cycles but im not too sure which one to try. What would you recommend? Also it does this on other games for example Toonstruck.
And for the mount options:
mount C "CONST"
mount D "E:\" -t cdrom
I'm using the DOSBox Game Launcher, thats why it mounts it to CONST (Constructors folder.) I've also tried running it direct, (skipping the launcher) and it makes no difference.
Reply 10 of 33, by robertmo
don't use Launcher and
follow the 60 seconds guide from the beginning
Reply 11 of 33, by AtlasRapture
I've followed that guide and tried it without the launcher already and it still does the same thing.
Reply 12 of 33, by robertmo
where have you got dosbox from?
Reply 13 of 33, by AtlasRapture
Running Dosbox version 0.74 from here.
DOSBox version 0.74
CONFIG:Loading primary settings from config file dosbox.conf
runs too fast try a fixed cycles amount in DOSBox's options.
mount C C:\Dosbox\dosroot
mount D E:\ -t cdrom
c:
cd CONST
game.exe
The game now gives an error:
Error = Problem opening FLICS FFS using D:\flics\DATA.FIL
Reply 14 of 33, by robertmo
you said "still does the same thing" and later that it is different now. So has the guide changed or what happened?
uninstall, delete, remove everything
and follow the guide step by step as it looks every time it is different for you
Reply 15 of 33, by AtlasRapture
Yeah I don't know why it changed. Anyway just tried re-installing it and still get the same error.
Reply 16 of 33, by robertmo
make a cd image and use imgmount
Reply 17 of 33, by AtlasRapture
How do I do that? The directions in the read me are a little to complex for me.
Reply 19 of 33, by AtlasRapture
Ok i've created an iso of the games disc and using imgmount it just asks for the games disk like before. Heres my mount options:
mount C C:\Dosbox\dosroot\CONST
imgmount D C:\CONST.iso -t iso
Am I doing anything wrong? And does the filename of the iso need to be the same name as the original CD?
