First post, by Malik
- l33t
Just wondering if anyone managed to find a way or patch or hex edit the install.exe fileto bypass the AWE32's installation routine of detecting the ICM (Intel Configuration Manager) of the former non-PnP cards or the CTCM of the newer PnP cards?
It's quite annoying if I just want to reinstall the appplications, especially for Windows 3.1x, and when I'm using the installation in different pcs. The former (non-PnP) cards' installation program won't proceed with the installation if the ICM is not detected (not loaded, whereas the CTCM is already loaded).
It's troublesome to reload the ICM while CTCM is loaded. And the later installation programs will not proceed when CTCM is not detecetd, and the same problem applies here too.
So, has anyone found out the way yet, other than loading the respective managers?
