dosbox not recognising network filesystems
First post, by flowirin
running ubuntu 10.04, dosbox 0.73
amd phenom II x4, gigabyte MB
i'm mounting a folder shared from a winXP box with the following fstab entry:
//server/share /home/office/share cifs credentials=/home/office/.smbcredenti
als, defaults 0 0
when i run
mount l /home/office/share
i get the response
Directory /home/office/share doesn't exist
the same occurs if i mount using smbfs, or hard set the UID/GID.
i've tried mount --bind /home/office/share /share
and then mounting that /share in dosbox, but it is also not recognised.
Reply 1 of 20, by wd
Rank DOSBox Author
DOSBox Author
dosbox 0.73
Why?
Reply 2 of 20, by leileilol
Because that's the most 'up-to-date version ever possible' in the Ubuntu repository.
long live PCem
Reply 3 of 20, by flowirin
indeed. the why is unecessary.
tried using v 0.74 as well. same problem
Reply 4 of 20, by wd
Rank DOSBox Author
DOSBox Author
Build 0.74 from sources, and debug the mounting. Nothing special in there.
Reply 5 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
Specific to samba or do NFS things fail as well ?
Water flows down the stream
Reply 6 of 20, by flowirin
wd. i can't say that i understand the intention of your posts. perhaps, if you are so skilled, you could reproduce the error and enlighten us all.
i'm an end-user, not a programmer
i downloaded and built 0.74 from sources, following instructions. i've also tried with the megabuild 5.
i'll test for nfs shares tomorrow
Reply 7 of 20, by wd
Rank DOSBox Author
DOSBox Author
Don't reopen every samba related post next time, and if you do, at least take the time to READ them.
Reply 8 of 20, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
mount c \\computer\share does not work.
mount c \\computer\share\subdirectory does.
1+1=10
Reply 9 of 20, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
stat doesn't play along.
A suggestion for somebody who knows this code better than me (only tested on Windows):
1+1=10
Reply 10 of 20, by wd
Rank DOSBox Author
DOSBox Author
So stat \\computer\share does not work? Does stat \\computer\share\
work any better? Or \\computer\share\. if that works at all.
Reply 11 of 20, by flowirin
i'm lost.
i've searched extensively for posts relating to dosbox mounting samba shares, with keywords cifs and smbfs, linux, unix, ubuntu.
on the whole net i found 2 entries, one of them in these formus, which was not resolved. the other refers to a different virtual box.
so wd, if you can point me to other posts, please do. i don't get your references, its all a bit cryptic.
h-a-l, is what you are saying for me? what is that file?
Reply 12 of 20, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
No it's not for you.
1+1=10
Reply 13 of 20, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Ah, stat(\\computer\share\) works.
Seems offtopic in this thread though.
1+1=10
Reply 14 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
hmm treating it as a root directory
Reply 15 of 20, by mentrick
i have the same problem... in a previous version of dosbox, that i can't say which, i worked well... but now, not anymore..
someone to help???
thanks
Reply 16 of 20, by DBob
Same problem here.
I want to store every of my files used by dosbox on my nas. It's being mounted to /mnt/nas, and everything else van access it, except dosbox.
I've also tried the "\\computer\share" access method, without any success. Also tried with + \subdirectory.
Is there any workaround to it? Because I'm using lts ubuntu, the version of dosbox sure won't change for loong time, and I don't want to change to non-lts in the future.
Reply 17 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
think I once debugged it on irc.
Problem was some mount flag when mounting your nas in ubuntu.
serverino or noserverino was the solution. Not sure which one.
Reply 18 of 20, by DBob
Thanks for the info, it's great now.
The correct one is noserverino.
By the way, I'm hoping this doesn't effect anything else 😀
Reply 19 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
it's not a dosbox bug that you are working around with that switch.
