First post, by DosFreak
http://www.softsystem.co.uk/products/soundfx.htm
via: http://win2kgaming.site90.com/phpBB2/viewtopic.php?f=6&t=652
SoundFX 2000 is THE sound card emulator for DOS programs running on Windows XP, 2000 and NT4. As delivered, these systems provid […]
SoundFX 2000 is THE sound card emulator for DOS programs running on Windows XP, 2000 and NT4. As delivered, these systems provide a DOS emulation for running 16 and 32 bit protected mode programs but due to the security model, direct peripheral access is denied. Most DOS multimedia titles (games) provide sound by directly accessing the sound card and as a result although many can be run under Windows, until now none have been able to produce sound and hence lose a great deal of playability.
SoundFX provides a complete emulation of a SoundBlaster 16 card and hence enables old favourites such as Doom (1 & 2), Heretic, Duke Nukem (2 & 3D) etc to be run with sound under Windows XP, 2000 & NT4.
Features
* Complete software emulation of the Adlib FM synthesiser. Ideal for sound cards like the SBLive which don't have FM synthesiser hardware, restoring music to many DOS games.
* Now uses DirectSound features for even lower overhead and better digitised effects.
* MPU401/Roland emulation provides general MIDI music for best quality and lowest overhead. Now supports MIDI input for music composition software.
* Support for a standard games port providing 4 analogue & 4 digital inputs. Ideal for flight sims requiring yoke, throttle, rudder pedals and POV hat.
* Complete SoundBlaster, 2, Pro, 16, AWE32 emulation for wave effects.
* Extensive online help for installation and use
Limitations
SoundFX is now open source. It may be freely used by any individual for personal or private use or for their business without any restriction or charge. Companies, organisations or governments may not use it without a license. In no case may SoundFX be used to deprive anyone of life, liberty or livelihood.
Make your games work offline
Reply 2 of 3, by rcblanke
Thanks for the heads-up, DosFreak!
Reply 3 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
he he, that was a bookmark for quite some time on my system, though VDMSound was much more reliable most of the times. Nice that they made it opensource now...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
