First post, by Bozlifyme
Before you say anything. Yes, I have read the README and yes, I have read whats already on the forum. Neither have been able to help me.
I'm running DOSbox though Boxer for the Mac (MacBook Pro v.10.5.😎 and I'm trying to play Lighthouse: The Dark Being. I installed the 1st .iso file and have been able to play up to parts where I have to switch CDs but I haven't been able to figure out how to get DOSbox to load the 2nd CD iso.
If anyone's had the same or similar problem, please enlighten me on how to fix. Thanks in advance!
Reply 1 of 2, by collector
Make sure that you have mounted both images, then you can swap the images. On PC it is Ctrl+F4. I'm not sure what it would be on a Mac, perhaps Option+F4? Ii should be in the README. Look under imgmount. There are several Mac users here that can give you a more definitive answer.
