First post, by baer
								baer
								Offline
			Hi,
Just wanted to let you know that there is a software out there which allows you to mount floppy disk images under Windows, very similar to the way you do it in DOSBox.
So ... if you don't have a physical floppy disk drive anymore, maybe this virtual floppy disk drive is what you are looking for.
http://chitchat.at.infoseek.co.jp/vmware/vfd.html
The software works under Windows XP ... up to Windows 7 - 32 bit versions only.
