First post, by toddbailey
Are there any how to set up guides to make win 3.1 work?
I installed and the mouse doesn't track very well, it will follow part way into the window then quit.
Any ideas or guides on how to fix and get better screen resolutions, fix problems I haven't found yet?
thanks
Reply 1 of 11, by IIGS_User
For me, directly after installing w31 the mouse pointer doesn't move at all.
Have to quit freshly installed w31 by pressing Ctrl-F4, then to restart w31 (not the entire DOSBox), and the mouse works fine.
Klimawandel.
Reply 3 of 11, by IIGS_User
Sorry, Alt-F4 is the true key combo.
Usually, this closes particular windows, so press it until you get the msg to confirm to quit Windows 3.
Klimawandel.
Reply 4 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
He he... Doing that in dosbox will just close dosbox (if you are hosting on Windows) 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 11, by Dominus
DOSBox Moderator
oh, that's new for me (had to test it right now... se rant further down). It used to close Dosbox in the past 😀
@todd, please see the guide at Windows 3.1x DOSBox Guide it has some pointers on mouse issues. if that doesn't help which graphics driver and mouse driver are you using in windows 3.1x?
My rant: on my laptop with Windows 7 I had installed that Windows Anti-Virus solution Windows Essentials or something like that. This did prevent my download of dosbox in both firefox and IE because that stupid program scanned the files and because it was both not up to date with program and virus signatures it failed silently and hid the download somewhere... Only when I disabled Firefox 3.x silent pass through to installed AV program was I able to download Dosbox on that laptop....
Reply 10 of 11, by Dominus
DOSBox Moderator
Hmm, I pretty sure alt-f4 once posed problems for me in Windows. That could have been ages ago, though...
@todd can you look up the alternative links? After the weekend I might be able to fix some links.
Reply 11 of 11, by toddbailey
That's right, I read the guide's info provided on the link
from there the links to video drivers, and the drivers have been deleted.
I suspect installing the s3 drivers might fix the mouse problems but can't test to be certain...
Turns out I need to install win 95 any way...
which is turning out to be a pain in the ? as well.
