First post, by bozalina
I've attached an XBOX 360 controller for Windows to my Win7 x64 box. It seems as though it's not receiving the jaxis_0_2 (+ & -) event, which is the left and right rotation for the right hand analog stick. All other joystick events work fine.
I've tried setting the joysticktype to fcs and ch, but neither have helped. I've also tried adding mappings to the events in the keymapper, and editing mapper.txt directly, but neither have any effect. I believe it's a problem with the device itself, rather than the key mappings. Here's my command window when I launch the game:
DOSBox version 0.74 Copyright 2002-2010 DOSBox Team, published under GNU GPL. --- CONFIG:Loading primary settings from config fi […]
DOSBox version 0.74
CONFIG:Loading primary settings from config file dosbox.conf
MIDI:Opened device:win32
One joystick reported, initializing with 4axis
Using joystick Controller (XBOX 360 For Windows) with 5 axes, 10 buttons and 1 hat(s)
Is this a known issue anyone else has experienced, and if so, is there a solution?
