First post, by Ir8
I'm pretty sure I'm doing this right
After I hit enter,I get an Error code: -1 and a message (Could not find the text library)
I tried doing it right off the cd but that didnt work either
thnx
thnx
Ok,I'm going to try to do this from an .iso
What do I do next?
I'm running xp home sp2
AMD 3.2 mhz duel
4 gig ddr
Gforce 275 gtx
thnx
Type dir and check how to install the game.
I just had to type install :i
The game starts perfectly . Goes through a few stages,name,callsign,breifing roo,then to the hanger,weapons load out and when I go to mission,the game freezes and I get this error message.
Says writing CW.err file.. Where do I fing that ?
thnx
Found the CW>ERR file.
Can anybody decipher it.
CauseWay DOS Extender v3.25 Copyright 1992-96 Michael Devore.
All rights reserved.
Exception: 0E, Error code: 0004
EAX=FFFE4700 EBX=004C6B37 ECX=00006B37 EDX=FFFFC100 ESI=004C72DF
EDI=004C6B37 EBP=004A0758 ESP=004A0748 EIP=0043C9B9 EFL=00003285
CS=01A7-FFBCA000 DS=01AF-FFBCA000 ES=01AF-FFBCA000
FS=0000-xxxxxxxx GS=01AF-FFBCA000 SS=01AF-FFBCA000
CR0=00000000 CR2=00000000 CR3=00000000 TR=0000
Info flags=00008040
Program Linear Load Address: 00436000
CS:EIP > 8B 4C C3 0A 8B 56 0A C1 F9 10 C1 FA 10 8B 5C C3
08 8B 46 08 C1 FB 10 C1 F8 10 E8 A2 F4 01 00 83
C6 38 E9 57 FD FF FF 31 C0 E8 28 32 02 00 89 EC
5D 5F 5E 5A 59 5B C3 56 57 55 89 E5 83 EC 04 89
C6 89 D7 89 5D FC BB 01 00 00 00 31 D2 B8 08 E4
48 00 8A 15 00 ED 48 00 E8 8C 29 02 00 8B 5D FC
8D 57 01 89 F0 43 E8 BD 2E 02 00 BB 01 00 00 00
B8 08 E4 48 00 89 CA E8 6D 29 02 00 8B 5D FC 89
FA 89 F0 E8 A0 2E 02 00 89 EC 5D 5F 5E C3 90 53
52 55 89 E5 89 C2 A1 40 0F 49 00 0F BF 18 83 FB
FF 74 10 66 83 78 34 00 74 04 66 89 50 34 83 C0
38 EB E8 31 C0 5D 5A 5B C3 8B C0 56 57 55 89 E5
89 D6 66 85 C0 7D 0A B8 FF FF FF FF E9 7B 00 00
00 66 3B 05 44 0F 49 00 7C 0B B8 FF FF FF FF 5D
5F 5E C2 10 00 0F BF D0 8D 04 D5 00 00 00 00 29
D0 8D 14 C5 00 00 00 00 A1 40 0F 49 00 01 D0 66
SS:ESP > FA 00 00 00 68 07 4A 00 37 6B 4C 00 F4 07 FF FF
84 07 4A 00 37 6B 4C 00 58 60 4C 00 90 00 00 00
34 01 00 00 9C 01 00 00 97 AB 43 00 00 00 00 00
00 00 00 00 7F 02 00 00 DF 01 00 00 12 07 4A 00
05 00 00 00 3B 84 43 00 2D 20 4C 6F 63 61 6C 20
73 65 61 73 20 33 20 66 6F 6F 74 20 73 77 65 6C
6C 73 2E 0A 00 65 65 74 2E 0A 00 32 2E 32 2E 32
3A 0A 0A 54 61 6B 65 20 6F 66 66 20 66 72 6F 6D
20 74 68 65 20 47 72 6F 75 6E 64 0A 0A 4C 65 61
72 6E 20 74 6F 20 74 61 78 69 20 61 6E 64 20 74
61 6B 65 20 6F 66 66 20 66 72 6F 6D 20 61 20 6C
61 6E 64 20 62 61 73 65 64 20 61 69 72 70 6F 72
74 2E 0A 00 83 00 83 00 68 06 00 00 38 00 00 00
60 08 4A 00 30 08 4A 00 21 00 00 00 27 0A 00 00
00 00 00 00 73 00 AF 01 73 00 63 00 80 08 4A 00
D4 63 0D 00 00 00 00 00 00 00 00 00 73 00 AF 01
37 6B 4C 00 02 00 00 00 E2 00 00 00 3E 36 0A 00
00 00 00 00 02 00 00 00 9C 06 4A 00 37 6B 4C 00
6F 72 4C 00 CD 00 00 00 E2 00 00 00 FA 00 00 00
E0 C5 45 00 3E 01 00 00 E2 00 00 00 FA 00 00 00
3E 36 02 00 F0 06 4A 00 37 6B 4C 00 6F 72 4C 00
E2 00 00 00 74 EE 45 00 43 00 00 00 5E 00 00 00
E0 00 00 00 9F 00 00 00 3E 01 00 00 00 00 00 00
00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 40
00 00 00 00 00 00 00 A0 01 00 00 00 14 07 4A 00
9C 01 00 00 F8 1D 00 00 38 07 4A 00 37 6B 4C 00
A7 72 4C 00 5E 67 00 00 9F C0 45 00 01 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 ED 72 4C 00
E8 14 00 00 AF 0A 00 00 01 00 00 00 3C 07 4A 00
E8 14 00 00 ED 72 4C 00 AF 01 00 00 37 6B 4C 00
00 47 FE FF 35 06 00 00 27 01 00 00 85 32 00 00
SS:EBP > 84 07 4A 00 37 6B 4C 00 58 60 4C 00 90 00 00 00
73 00 AF 01 73 00 63 00 9C 08 4A 00 D4 63 0D 00
Application resource tracking details
Selectors
sel base limit type D mem count
018F 00431000 00004000 DATA 32 Y xxxx
019F 00431AEC 00000153 DATA 32 Y xxxx
01A7 00000000 FFFFFFFF CODE 32 N 0001
01AF 00000000 FFFFFFFF DATA 32 N 0002
01B7 00431C48 00000043 DATA 32 Y xxxx
Total selectors: 0005
Linear memory blocks
handle base length
00436000 00436000 0006C000
00431AEC 00431AEC 00000154
00431C48 00431C48 00000044
Total Linear memory: 0006C198 (00070000) in 00000003 blocks
Linear memory locked
base length
78500046 0000000B
0046F595 000000FF
0046F6A9 0000009A
00469515 00000692
00475577 00000C64
004761F0 0000003F
00468158 000009DC
0046F2C3 000002BD
0046EBB5 000006F9
0046928B 00000275
00467FCC 000000AE
00468B49 0000072D
0046F758 000007E3
0047043C 000002A1
0046FF64 000004D4
00476244 00001F41
00478188 00000969
004879D8 00000564
00488A58 000000F6
00488BA4 00002038
00488B54 0000004C
004B3000 000006E2
004AB440 00001E00
004AD248 00004000
0046F595 000000FF
0046F6A9 0000009A
00469515 00000692
00475577 00000C64
004761F0 0000003F
00468158 000009DC
0046F2C3 000002BD
0046EBB5 000006F9
0046928B 00000275
00467FCC 000000AE
00468B49 0000072D
0046F758 000007E3
0047043C 000002A1
0046FF64 000004D4
00476244 00001F41
00478188 00000969
004879D8 00000564
00488A58 000000F6
00488BA4 00002038
00488B54 0000004C
00479E37 00000450
004742A1 000000D7
004749D9 00000A14
00471AA7 0000017E
00471C3A 00000DB5
00473A94 0000008B
004792E9 00000B10
00472A04 0000107B
0046CE20 0000081C
0046D651 0000013F
00474563 000002F2
00473D19 00000573
0047917F 00000155
00475402 000000F7
0046D9D4 00000105
0046D7A5 0000021A
00474912 000000B2
0046BBE9 000008BD
0046CB60 000002AB
0046DF1D 00000401
0047169E 000003F4
0046DAEE 0000041A
0047486C 000000A5
0048ACF8 000010FE
004BC000 00003850
004B2CB0 00000241
004BABA8 00001200
004A2FB8 0000001F
004C2B18 00001200
004A2FE0 0000001A
DOS memory blocks
sel base length
Protected mode interrupt vectors
No sel offset
08 01A7 0047043D
09 01A7 0045CE4C
0F 01C7 00000674
10 01A7 0046E3DD
23 01A7 0045D538
24 01A7 0046A02A
Protected mode exception vectors
No sel offset
Real mode interrupt vectors
No seg offset
Call-Backs
real target
thnx
Try with DOSBox from www.dosbox.com
1+1=10
I reinstalled from 0.74 and got it workig. F22 worked too.
thnx much...
Here is how I got it to work fr anybody who wants to know.
I made a .nrg image of my disc useing Nero then made an .iso useing nrg2iso.exe.
I made a folder in C: images and put my .isos in it.
I just could'nt get it to work from the cdrom.
Then I put it in dosbox.
then i hust type jf3 and the game run great.
