First post, by Serious Callers Only
music / sound effects / speech
mt32 / sb / sb -> hang
mt32 / sbp / sbp -> dynamic core crash when starting game:
Exit to error: DynrecCore: illegal option in dyn_grp4_ev
I am using the munt emulator deamon.
Reply 1 of 5, by Serious Callers Only
Oh yeah, dosbox 0.73
Reply 2 of 5, by Serious Callers Only
And it's a dosbox crash, not a game crash, just to clarify.
Reply 3 of 5, by Serious Callers Only
I don't want help for this since i can start the game with all sounds with
mt32/mt32/sbpro
but i thought that the crash should be reported.
Reply 4 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
First of all, use 0.74; I mean, do you really think a problem report for an old version is of much value?
Also, please give at least some basic information about what operating system you're using, which version number of the game (if known), CD or floppy version, whether you've applied the latest patches available for it, any non-default conf settings you're using, and the commands you use to run the game including mount lines.
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
It's a game crash (executing rubbish) and there's no point for dosbox to continue,
therefore the graceful exit, not crash.
As ripsaw noted it's a pretty information-less report.
