editing .conf file
First post, by 1daemon1
Hi guys,
When i use commands as: copy, ren, del or echo text>file.conf it allways change name of file file.CONF to file.CON. How i can fix for example this code ?
mount c /home/michal
c:
copy file.conf Desktop\file.conf
can anyone help me please ?
Reply 1 of 5, by OSH
This is limitation of DOS itself. DOS up to 6.22 accept only 8 signs for filename plus 3 signs for extension. I think it can't be solved...
Reply 2 of 5, by 1daemon1
What a pity 😢 . Thanks for reply.
Reply 3 of 5, by robertmo
if file.conf is a dosbox's configuration file so f is not needed 😉
Reply 4 of 5, by Nathan
Now you can use such commands work with long file names. You just need to install a tool called LFN Tools. 😉
Reply 5 of 5, by IIGS_User
If file.conf is a dosbox's configuration file so use your standard text editor instead.
Klimawandel.
