First post, by LTKodiak
I am having considerable difficulties with the imgmount for the mechwarrior 2 cue/bin file with music. Each time I attempt to mount the file, I receive the following error message:
Could not load image file: c:\oldgames\mwcue\MECH2.cue
MSCDEX: Failure: Invalid file or unable to open.
I have searched the various help areas in the forum, beginners' guides, etc, and even attempted my luck in google, but I have not found a solution to this problem.
EDIT: Also, I currently use DOSBox 0.74
Also, here is the .cue file that I have for this:
FILE "MECH2.bin" BINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
FILE ".\music\track2.ogg" MP3
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 00:00:00
FILE ".\music\track3.ogg" MP3
TRACK 03 AUDIO
INDEX 01 00:00:00
FILE ".\music\track4.ogg" MP3
TRACK 04 AUDIO
INDEX 01 00:00:00
FILE "\music\track5.ogg" MP3
TRACK 05 AUDIO
INDEX 01 00:00:00
FILE "\music\track6.ogg" MP3
TRACK 06 AUDIO
INDEX 01 00:00:00
FILE "\music\track7.ogg" MP3
TRACK 07 AUDIO
INDEX 01 00:00:00
FILE "\music\track8.ogg" MP3
TRACK 08 AUDIO
INDEX 01 00:00:00
FILE "\music\track9.ogg" MP3
TRACK 09 AUDIO
INDEX 01 00:00:00
FILE "\music\track10.ogg" MP3
TRACK 10 AUDIO
INDEX 01 00:00:00
FILE "\music\track11.ogg" MP3
TRACK 11 AUDIO
INDEX 01 00:00:00
FILE "\music\track12.ogg" MP3
TRACK 12 AUDIO
INDEX 01 00:00:00
FILE "\music\track13.ogg" MP3
TRACK 13 AUDIO
INDEX 01 00:00:00
FILE "\music\track14.ogg" MP3
TRACK 14 AUDIO
INDEX 01 00:00:00
FILE "\music\track15.ogg" MP3
TRACK 15 AUDIO
INDEX 01 00:00:00
FILE "\music\track16.ogg" MP3
TRACK 16 AUDIO
INDEX 01 00:00:00
FILE "\music\track17.ogg" MP3
TRACK 17 AUDIO
INDEX 01 00:00:00
FILE "\music\track18.ogg" MP3
TRACK 18 AUDIO
INDEX 01 00:00:00
FILE "\music\track19.ogg" MP3
TRACK 19 AUDIO
INDEX 01 00:00:00
FILE "\music\track20.ogg" MP3
TRACK 20 AUDIO
…Show last 22 lines
    INDEX 01 00:00:00
FILE "\music\track21.ogg" MP3
TRACK 21 AUDIO
INDEX 01 00:00:00
FILE "\music\track22.ogg" MP3
TRACK 22 AUDIO
INDEX 01 00:00:00
FILE "\music\track23.ogg" MP3
TRACK 23 AUDIO
INDEX 01 00:00:00
FILE "\music\track24.ogg" MP3
TRACK 24 AUDIO
INDEX 01 00:00:00
FILE "\music\track25.ogg" MP3
TRACK 25 AUDIO
INDEX 01 00:00:00
FILE "\music\track26.ogg" MP3
TRACK 26 AUDIO
INDEX 01 00:00:00
FILE "\music\track27.ogg" MP3
TRACK 27 AUDIO
INDEX 01 00:00:00
Reply 2 of 4, by ADDiCT
I didn't test images with encoded audio myself yet, but did you try moving the ogg files to the same directory the bin file is in, and removing the paths in the cue file?
Reply 3 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The paths to the first 3 audio tracks start with a dot, so they are relative pathed; and the rest do not have a dot, so they are absolute pathed. Nothing conclusively wrong about it, but it looks strange, and could be the source of your problem.
Reply 4 of 4, by LTKodiak
Pardon that omission,
I am using Windows Vista. However, I've gotten Mechwarrior 2 (DOS) running, just without the music. But, I am kind of a purist, and if I want MW2 DOS to work, I bloody well gotta have the tunes. I will however attempt addict's and ripsaw's fixes.
EDIT: I attempted both recommendations, placing all the .ogg files in the same folder as the bin/cue file, and also modifying the .cue file by adding dots to all the prompts as well as removing the dots, unfortunately with no success.
EDIT 2: I took a second look at addict's recommendation, and I noticed that I forgot to take out the pathways. That is done, and now the imgmount works, and the music is working ingame. Problem solved, thanks.
