First post, by vinceohm
On Mac Snow Leopard
After
./configure --enable-debug=heavy
make gives:
In file included from core_dyn_x86.cpp:238:
core_dyn_x86/decoder.h: In function ‘CacheBlock* CreateCacheBlock(CodePageHandler*, PhysPt, Bitu)’:
core_dyn_x86/decoder.h:2006: error: cast from ‘CacheBlock*’ to ‘Bit32u’ loses precision
make[4]: *** [core_dyn_x86.o] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
After
./configure --enable-debug=heavy --disable-dynrec
make gives:
After
./configure --enable-debug=heavy --disable-dynrec --disable-dynamic-x86
make gives:
debug_gui.cpp:149: error: invalid use of incomplete type ‘struct _win_st’
/usr/include/curses.h:322: error: forward declaration of ‘struct _win_st’
debug_gui.cpp:151: error: invalid use of incomplete type ‘struct _win_st’
debug_gui.cpp:153: error: invalid use of incomplete type ‘struct _win_st’
debug_gui.cpp:155: error: invalid use of incomplete type ‘struct _win_st’
debug_gui.cpp:157: error: invalid use of incomplete type ‘struct _win_st’
make[3]: *** [debug_gui.o] Error 1
Any help?
Thanks.
Reply 1 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
did you do ./autogen.sh as well? Also I'd advise to build in 32bit on OS X. The 64bit dynamic core will crash when you run Dosbox and it switches to it (but I guess you know that because you disabled it)
To compile in 32bit I built by
cd ~/Code/svn/dosbox
export CFLAGS='-O2 -arch i386 -fomit-frame-pointer -fstrict-aliasing -momit-leaf-frame-pointer -fno-tree-pre -falign-loops -ffast-math' CPPFLAGS='-I/opt/local/include' CXXFLAGS='-O2 -mdynamic-no-pic -arch i386 -fomit-frame-pointer -fstrict-aliasing -momit-leaf-frame-pointer -fno-tree-pre -falign-loops -ffast-math' MACOSX_DEPLOYMENT_TARGET='10.6' CXX='/usr/bin/g++-4.2' F90FLAGS='-O2 -m32' LDFLAGS='-L/opt/local/lib -arch i386 -O2 -fomit-frame-pointer -fstrict-aliasing -momit-leaf-frame-pointer -fno-tree-pre -falign-loops -ffast-math' OBJC='/usr/bin/gcc-4.2' FCFLAGS='-O2 -m32' OBJCFLAGS='-O2 -arch i386' FFLAGS='-O2 -m32' CC='/usr/bin/gcc-4.2'
./autogen.sh
./configure --disable-sdltest --disable-alsatest --enable-core-inline
make clean
make
I haven't built very latest SVN but at least around the release time of 0.74 SVN didn't give me any headache (but I also didn't build with debug).
Also I'm using MacPorts to have all needed libs built in universal flavor 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 9, by vinceohm
Thanks for you quick answer.
Well I don't really know... I've just seen some of your posts elsewhere.. 😉
I tried your script (the 5 commandes) and got :
Undefined symbols:
"_SDL_UnlockAudio", referenced from:
MixerChannel::FillUp() in libhardware.a(mixer.o)
MixerChannel::Enable(bool) in libhardware.a(mixer.o)
MIXER_Mix() in libhardware.a(mixer.o)
"_SDL_NumJoysticks", referenced from:
about 100 more lines
"_SDL_WM_SetCaption", referenced from:
GFX_SetTitle(int, int, bool)in libgui.a(sdlmain.o)
GUI_StartUp(Section*) in libgui.a(sdlmain.o)
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[3]: *** [dosbox] Error 1
Then I added --enable-debug=heavy to the configure line, and got:
debug_gui.cpp: In function ‘void DrawBars()’:
Reading you, I had used MacPorts and did:
 sudo port -d selfupdate
sudo port install libsdl
sudo port install p5-curses
sudo port install ncurses
sudo port upgrade outdated
Reply 3 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
the LDflags don't include a reference to sdl. so that explains the problems.
For the curses problem. Not sure what kind of curses mac os x has installed. Isn't there a different version somehow ?
I use ncurses.
Water flows down the stream
Reply 4 of 9, by Dominus
DOSBox Moderator
As I wrote above it needs to be universal, meaning you have to "sudo port install SOMETHING +universal" or else building Dosbox in 32bit will fail on modern Apple machines with OS X 10.6...
Reply 5 of 9, by Dominus
DOSBox Moderator
I got your debug build problem figured out now, since I first got the same error as you got.
You need to pass on the include for ncurses or ./configure will use the "bad" curses that comes with xcode by apple.
When you add -I/opt/local/include/ncurses to the CPPFLAGS it will built fine.
The whole export *I* use and which is working for me is
export CFLAGS='-O2 -arch i386 -fomit-frame-pointer -fstrict-aliasing -momit-leaf-frame-pointer -fno-tree-pre -falign-loops -ffast-math' CPPFLAGS='-I/opt/local/include -I/opt/local/include/ncurses' CXXFLAGS='-O2 -mdynamic-no-pic -arch i386 -fomit-frame-pointer -fstrict-aliasing -momit-leaf-frame-pointer -fno-tree-pre -falign-loops -ffast-math' MACOSX_DEPLOYMENT_TARGET='10.6' CXX='/usr/bin/g++-4.2' F90FLAGS='-O2 -m32' LDFLAGS='-L/opt/local/lib -arch i386 -O2 -fomit-frame-pointer -fstrict-aliasing -momit-leaf-frame-pointer -fno-tree-pre -falign-loops -ffast-math' OBJC='/usr/bin/gcc-4.2' FCFLAGS='-O2 -m32' OBJCFLAGS='-O2 -arch i386' FFLAGS='-O2 -m32' CC='/usr/bin/gcc-4.2'
If you installed all the needed libs via macports and the +universal option and you still get the SDL errors a
export LDFLAGS=-L/opt/local/lib
might help.
@Qbix
I do get these warnings though
debug.cpp: In function ‘void LogGDT()’:
debug.cpp:1857: warning: format not a string literal and no format arguments
debug.cpp:1859: warning: format not a string literal and no format arguments
debug.cpp: In function ‘void LogLDT()’:
debug.cpp:1877: warning: format not a string literal and no format arguments
debug.cpp:1879: warning: format not a string literal and no format arguments
debug.cpp: In function ‘void LogIDT()’:
debug.cpp:1891: warning: format not a string literal and no format arguments
debug.cpp: In function ‘void LogPages(char*)’:
debug.cpp:1914: warning: format not a string literal and no format arguments
debug.cpp:1927: warning: format not a string literal and no format arguments
debug.cpp:1930: warning: format not a string literal and no format arguments
debug.cpp: In function ‘void LogCPUInfo()’:
debug.cpp:1939: warning: format not a string literal and no format arguments
debug.cpp:1941: warning: format not a string literal and no format arguments
debug.cpp:1943: warning: format not a string literal and no format arguments
debug.cpp:1945: warning: format not a string literal and no format arguments
debug.cpp:1951: warning: format not a string literal and no format arguments
debug.cpp:1956: warning: format not a string literal and no format arguments
Reply 6 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
you could do a const char* out2= &out1[0];
and replace the out1 with out2 in those LOG() calls.
Maybe that makes the compiler happy
Reply 7 of 9, by Dominus
DOSBox Moderator
I'm not sure I understood you right but in line 1848 I added the const char* out2= &out1[0]; and then replaced the out1 with out2 in the log calls. The compiler will still complain the same way.
Reply 8 of 9, by vinceohm
Thanks a lot Dominus, my make does it now!
Cheers,
Vince.
