Touch Screen Old Games!!
First post, by Lozzy0603
Hi All,
I'm using DosBox on my HP TouchSmart TM2 with Windows 7 x64 (multi-touch display).
Touchscreen sort of works in mouse capable old dos box games under fullscreen, the only problem is the range of the mouse is scaled ie a small move of the finger/stylus on screen represents an extreme move in dosbox.
It works slightly better under windowed mode.
Is there any way I might be able to overcome this? It seems to be just a case of screen resolution or ""mouse"" (touchscreen) drivers.
I'd be grateful for any thoughts. Old games are wicked using touchscreen otherwise.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
fry the mouselock option in the configuration file.
but it will never be perfect as a lot of dos games are only interested in relative movement instead of absolute position.
Water flows down the stream
