First post, by Click Beetle DX
Hello, everyone.
Mid-last year we released Sango Fighter for DOS as freeware. DOSBox is the program we recommend our fans use in order to enjoy playing it on modern OS', because it does such a fine job running the game properly.
However just the other day I noticed one problem: If the game is configured to play its digital audio through the Ad Lib card (instead of the Sound Blaster), DOSBox locks up. I can confirm that Ad Lib digital audio works fine on my 486 with authentic Ad Lib card installed. So, it appears to be a problem with the emulation.
The game can be downloaded for free from the official website:
www.sangofighter.com
The Ad Lib digital sound function can be tested via running the game's SETUP.EXE and selecting Ad Lib as the "sound effect" choice. Then, exit the setup program and run SANGO.EXE to see the problem.
Any help appreciated. Thank you for your time.
- Brandon Cobb
President, Super Fighter Team
Download Sango Fighter for free @ www.sangofighter.com !
Reply 1 of 8, by Harekiet
Rank DOSBox Author
DOSBox Author
Weird that it would look up but either way the adlib emulation ussually isn't up for digital output since we don't use small enough time intervals to generate the output.
Reply 2 of 8, by Click Beetle DX
Thank you for the reply.
Are there any plans to add support for digital sound through the Ad Lib card in the near future? We wish to minimize any potential issues our fans may have while playing our game products using DOSBox. Of course, I understand if such support isn't high on the list of future improvements.
- Brandon Cobb
Reply 3 of 8, by eL_PuSHeR
Why would anyone want to use Adlib for digitized sound effects if DOSBox already provides SB support? If it's for compatibility sake, that's okay, but using SB is preferable.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 8, by Click Beetle DX
Why would anyone want to use Adlid for digitized sound effects if DOSBox already provides SB support? If it's for compatibility sake, that's okay, but using SB is preferable.
By default, the game will be set to play its sound effects through the Sound Blaster. However should someone decide to experiment with the options and choose Ad Lib instead, it would be best if they didn't experience a DOSBox lock-up.
- Brandon Cobb
Reply 5 of 8, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There's an experimental patch to forward Adlib PCM playback attempts to the Disney device which is more suitable for this kind of output.
1+1=10
Reply 6 of 8, by Click Beetle DX
Interesting, but wouldn't that still leave this particular, game-specific issue unresolved?
I don't suppose, given the obscure nature of the problem, that it's likely it will be investigated and possibly fixed anytime in the near future?
Thanks.
- Brandon Cobb
Reply 7 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
Dunno. I guess I could take a quick look in the weekend at what the game does in adlib only mode.
Water flows down the stream
Reply 8 of 8, by Click Beetle DX
Thanks. That would be very kind of you, and I'd certainly appreciate it.
- Brandon Cobb
