First post, by x000111
Hello, I am running DosBox on Debian. I have done so in the past without problems. I am trying to install a game and I get the error:
Illegal Command: __insth.
"There is not enough space on c to install Police Quest II"
"Approximetly 1.8 mb of disk space are required"
Immediately, I found that using mount c ~/gamesDir -freespace 1024 would be the fix. After giving the drive up to 10GB of freespace, I realize there must be something else going on.
Does anyone know what else the problem might be? I have downloaded other games that did not require an install and they run fine.... it's just installing games, I am having problems with.
