First post, by Jair Crawford
I have tried installing the game on DOSbox, version 0.70, 0.72, 0.73, and 0.74 to no avail. Yet I read that this game is fully compatible and supported.
Ok, here's my issue. I followed all the directions to mount drives and directories. So, I start the install. It starts up fine. I choose the language, and then I enter the directory. But as soon as I do that, the install straight up crashes, and goes back to the dosbox screen. It... won't install. It crashes before it can install.
Can anyone tell me what's going on?
Reply 1 of 4, by robertmo
post your mount lines and what is written under every mount line
post what is written after you type "mount"
Reply 2 of 4, by Jair Crawford
mount c C:\C
drive C is mounted as local directory C:\C
mount d E:\
drive D is mounted as local directory E:\
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
try a -t cdrom with the second mount
Water flows down the stream
Reply 4 of 4, by Jair Crawford
You, Qbix, are brilliant! It's installing! Thank you!!!
Ok, I'm gonna install and do a test run. I'll let you know how it goes. Thanks again!!! 😁
Edit:
Ok, I'm running into an issue with setsound. It recognizes the drivers, but then I get a message saying "Error: Could not save configuration file"
Anyone know what's causing this?
Thanks again for all the help so far!
Edit (again):
Nevermind! I fixed it! Thanks again!!! w00t!!! 😁
- Jair C.
