First post, by DubDude
Hi all. Nice product! Used it for a couple old games some time ago and came away impressed I could still run so many old DOS programs as intended.
Well anyway, I've decided to attempt to tackle what many said couldn't be done, get a program called VDS Pro to work without booting to real DOS--all the while using a USB cable.
VDS Pro is a DOS-based OBD2 scan tool and reprogrammer for VW/Audi vehicles, for those who don't know.
I have a newer Ross-Tech Hex-CAN USB cable. With the normal drivers, it doesn't use a COM port. However, I found an alternate set of drivers for those who want to use 3rd party programs that only know to search for a cable using a COM port. That's when I got the bright idea to attempt using the USB cable with VDS Pro via DOSBox.
I'm running Windows 7 (64 bit). I've got the proper drivers installed, the cable is setup to operate on COM1 in Windows. Set the config file for DOSBox to recognize serial1 as COM1 (serial1=directserial realport:COM1).
VDS Pro starts up, appears normal, but it cannot establish communication. The DOSBox status screen comes up with:
Serial1: Opening COM1
Serial1: Desired serial mode not supported (9600,5,n,1)
That error will repeat (and sometimes the parameters of it change as the program tries different parameters to establish communications).
Any suggestions?
Not sure how to get all of the settings via Windows Device Manager. I don't see IRQ or anything listed (if it even uses an interrupt with a USB device, I don't know).
Reply 1 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The 9600,5,n,1 error message is most likely only a side effect.
- Try a DOSBox SVN build (something has been fixed)
- Try a non-USB serial port
- Try different settings for cycles
Serial port hacks that use strict timing to emulate other protocols generally have difficulties running in DOSBox as it is not a realtime system.
1+1=10
Reply 2 of 9, by DubDude
Thanks for the response, hal.
I did try your MegaBuild (MB5) and there was no difference. Same errors.
Unfortunately my PC only has USB ports and the dongle I've got is also USB, not a serial dongle with a USB adapter. I was hoping a virtual COM port would do.
Any suggestions on what cycle settings to try? Or is there at least a link that has better info for me to read more about these settings (I'm not that well versed on the subject)?
Reply 3 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
MB5 is quite old and does not include the fix.
1+1=10
Reply 4 of 9, by DubDude
Good to know. Back to v0.74 then.
I just noticed that my virtual COM1 does not use an IRQ. Would this cause an issue if DOSBox or whatever program I'm trying to use expects an IRQ?
Reply 5 of 9, by DubDude
It's an FTDI Chip based deal, if that helps. Would be interesting to know if there are other people who have successfully used other FTDI-based converters/drivers in DOSBox.
Reply 6 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The FTDI converters work better than the Prolific ones (driver bugs). There are a few settings in their device properties to play with, that is if you don't use a virtual serial port after all.
The IRQ is emulated internally so no need to worry about. IRQs inside DOSBox have nothing to do with those outside. 0.74 doesn't include the fix either, you need a SVN build.
1+1=10
Reply 7 of 9, by DubDude
Again thanks for the quick response. Appreciate the input.
Just tried the latest emucr SVN build, no such luck.
Only settings I see I can play with on the USB Serial port in Device Manager are as follows:
bps: 9600
Data bits: 8
Parity: none
stop bits: 1
Flow control: none
There's an advanced button, but it doesn't look like changing much in there would help.
Reply 8 of 9, by TeaRex
DubDude wrote:
Only settings I see I can play with on the USB Serial port in Device Manager are as follows: […]
bps: 9600
Data bits: 8
Parity: none
stop bits: 1
Flow control: none
All of this won't do a thing for you. It only sets the defaults used by those programs which don't bother setting their own values - such as some serial printer drivers. DOSBox is not one of these programs, so you will need to set up the right communication parameters inside the Application you're running in DOSBox. DOSBox then forwards the settings of its internal emulated COM port to the real Windows COM port driver.
tearex
Reply 9 of 9, by DubDude
Thanks for the response. I suppose it's just a matter of a little trial and error, then. I know I can change which COM port it attempts to use as well as bps and a couple other things in the program itself.
I tried changing the bps, it just changes the first digit in the error that shows up in the DOSBox console window.
So I shouldn't have to set any additional parameters in DOSBox other than serial1=directserial realport:COM1 theoretically? I've searched and noticed a few people setting some manual parameters for IRQ (which I now know won't be required for my case), bits, bps etc.
