external mpu401 and mt32: confused
First post, by ratfink
Sorry for the dim questions, I feel I should know this after reading this forum for some years...
I have an mt32 - how do I connect it to my pc - is it just to the joystick port on a soundcard [assuming the soundcard has an mpu401 built-in]?
How do I tell if my soundcard has an mpu401 interface? Do I just look at the device manager in 95/98? At what point do soundcards start having built-in mpu401? Does an sb2 have one? An sbpro2? An sb16 does presumably as it accepts daughterboards.
Under what circumstances would I need a roland external mpu401 and how do I connect it?
Reply 1 of 37, by Mau1wurf1977
Under bare metal MS-DOS you need a Roland MPU401 or compatible interface. Most midi ports on soundcards don't work with all Games...
Under XP, Vista and 7 you get this: http://cgi.ebay.com.au/USB-MIDI-Interface-Cab … =item3cb03b111f
It's a simple USB to midi adapter.
Under 95 and 98 I guess you also need a Roland MPU401 compatible card.
Have a look here, this is the ISA MPU401 card I got recently on ebay: Bought these (retro) hardware today
Under Windows 7 I use that USB to Midi adapter
Reply 2 of 37, by DBob
The first cards at the Creative Labs which included a MPU-401 interface, the SB16 series.
If you are using an sb16+ or some clone with mpu401, you don't need pure roland interface. But sadly, even gravis cards don't have mpu401 🙁
Reply 3 of 37, by Mau1wurf1977
Some games require a "intelligent mode" MPU401 interface and soundcards don't have that. So you will find that some games simply don't work 🙁
There are a few threads on this in the archive. A fellow user did some tests and games such as Wing Commander wouldn't work.
My YouTube channel
Reply 4 of 37, by ratfink
thanks. so if i have an sbpro2 and a gus, there seems no way to connect an mt32 without either:
- adding a soundcard with an mpu401 interface incorporated into it, and accessed via the joystick port
or
- a roland interface card to connect the mpu401 interface to the pc [mif-ipc i think its called]. this is where i got confused... i thought the mpu401 was the pc/midi-device interface but in fact it needs an interface itself.
is the mif-ipc the only way to attach the mpu401 to a pc or are there other cards to look out for?
Reply 5 of 37, by Mau1wurf1977
Pictures say more than words 😁
Option 1: Soundcard with a MPU401 port + joystick port to midi cable + MT32.
Main benefit: Many soundcards have this port
Main drawback: Doesn't support the "intelligent mode", so some games won't work (though many will). "Hanging note" bug on many Sound Blaster cards.
Option 2: A Roland MPU401 or compatible (mine is a clone) card + midi cable + MT-32
Main benefit: Supports "intelligent mode", so every game should work.
Main downside: Harder to find
Option 3 (For DOSBox): A machine that runs DOSBox + USB midi interface + MT-32
Main benefit: Really really cheap (Like 5 bucks shipped) and easy to obtain (ebay).
Reply 6 of 37, by ratfink
thats great, thanks. but how does this one fit in:
Reply 7 of 37, by Mau1wurf1977
It's missing the ISA card. A lot of sellers sell these MPU401 boxes but without the ISA card they are useless...
Look at the top left of that box it says "To Computer".
In a nutshell before you could buy a simple card like the one I have, Roland sold you a ISA card + external box.
Many of these had issues with fast computers (Or the ISA slot running faster than 4.7 MHz or something like that), so Roland made a MPU401AT (AT for AT computer) and there are many clones of this card (the midiman MM401 being one and there is also one from Midi Quest).
So yea maybe I should have said "Roland MPU401AT compatible" 😉
Reply 8 of 37, by DBob
I've never met such games. I wonder, if there is a list with games, not working correctly with mt-32 using non roland midi out..
Reply 9 of 37, by Mau1wurf1977
Interesting, what MT-32 / midi connection do you use?
A fellow user here did some tests with his AWE and joystick midi cable. I will try to find it... Wing Commander was a game that wouldn't work.
There is a patch to get Sierra games going. But that's all I know.
EDIT: I simply can't find this thread, but I guess the fact that you need a patch for Sierra games to use your MT-32 through a joystick midi interface would be enough proof?
Source: http://www.queststudios.com/quest/Utilities.html
SOUND BLASTER MIDI PORT UTILITY
Reply 10 of 37, by DBob
I wasn't searching for proof, instead of some kind of list with these games not working, or not properly other then a pure Roland interface.
Btw, I have a Roland MPU-IPC-T, and I still need that Sierra patch to get the games working with mt-32 + mpu-ipc-t 😀
Reply 11 of 37, by DBob
Hmm...it seems I've found a which not works with a non-roland mpu interface: slipheed.
edit: another one is test drive 3 😠
Reply 12 of 37, by Mau1wurf1977
Really? Sure it isn't just an updated MT-32 driver?
As for a game list, yea never came accross one in my many many hours of internet research...
I only remember Wing Commander though...
What machine are you running it on? How fast is it?
Reply 13 of 37, by Mau1wurf1977
I found some more titles that shouldn't work:
Simon the Sorcerer 1
Waxworks
Battle Arena: Toshinden
Eric the Unready (But it's because it needs MPU-401 intelligent mode)
Wing Commander
My YouTube channel
Reply 14 of 37, by aitotat
DBob:
Are you sure that you are using IRQ 2 and port 330h on the Roland MPU-IPC-T? Some games require those and won't work with any other settings.
Mau1wurf1977:
I see you have Midiman. I have one too but without cable. Could you possibly check the wiring if you have multimeter? That would help me build my own cable.
Reply 15 of 37, by Mau1wurf1977
aitotat wrote:
Mau1wurf1977:
No problem:
Open this PDF: http://www.mackie.com/pdf/Serial9_ig.pdf
Last page there is a pinout.
I confirmed the Midi - Out pinout on my cable with my Multimeter!
Reply 16 of 37, by aitotat
Thank you! That is all I need to build my own cable.
Reply 17 of 37, by Mau1wurf1977
Cool! Let us know if it worked!
Remember the Midi-Out on the card goes into the Midi-In on the MT-32.
The MM401 has 8 dip switches.
Configure it to Address 330 and IRQ 2.
The dip settings from 330 / 2 from 1 to 8 are (holding the card upside down so you can read the ON and 1 to 8 writing):
on off on on on off off off
Reply 18 of 37, by DBob
Yep. But this has nothing to do with fixed 300h or 330h port games. Sierra has an another patch for change this
Reply 19 of 37, by aitotat
I had lots of problems (I hate soldering DIN connectors) but I was finally able to get it to work. I needed to switch wires 4 and 5 on the DIN connector to get it work. I'm sure I connected it correctly since the pin numbers are marked on the soldering sides for both D and DIN connectors.
It works now and even intelligent mode games from Sierra seems to work. Not without problems since there are some stuck notes (I'm using first generation MT-32). I have not experienced any stuck notes with Roland Midi controllers so this is might be related to Midiman (I haven't tried any Rolands with this 386). Have you experienced any stuck notes?
