ere is the entirety of it
mount e "e:\" -t cdrom
MSCDEX installed
drive e is mounted as CDRom e:\
mount c "c:\iron3"
Drive C is mounted as local directory c:\iron3\
c:
iron
then the intro start and the sound just ... dies. after the intro it shows nothing.
So i tried moving the files needed for the game to the IRON_CD folder on my HD ,but I get the Cannot Open 'Math.Dat' error.. I have not only the original cd (though very old and with lots of scratches) I know i dled a rip of the CD from home of the underdogs which gave me in the first zip
IronAssault.ace
and IronAssault.c00 -.c13
along with a instruction about the rip
when I open the .ace in winrar i got the games\iron folder and the Iron_CD folder along with a install note folder. Here is the info inside the two notes
First note in the main zip
notepad files name: Iron Assault
note's information:
IRON ASSAULT CD-"RIP"
Ripped by: EddyB43
Source: 20 Giant Games collection.
Install Instructions
Extract the ACE files with directory structure (the x command instead of e
in DOS ACE programs) into the root of your hard drive. From here you can go
into the GAMES\IRON directory and run cdinst.bat to configure your controls
and sound card, and just run IRON.EXE to play the game.
The game can be burnt to CD and played like the normal bought game by just
burning the IRON_CD dir (it is hidden on a normal CD) and the GAMES\IRON dir
to the same locations on the CD - eg. the CD tree would look like this:
D:
Ý-GAMES
Ý Ý-IRON
Ý-IRON_CD (Hidden file attribute)
You can then use CDINST.BAT to install the basic games files to your HD while
keeping the movies on the CD.
and what was in the Install notes folder
INSTALLING IRON ASSAULT
Just extract with folders to the root directory of your hard drive. The
IRON_CD & GAMES\IRON dirs can be written to CD and you can then run CDINST.BAT
to install configuration data from the CD.
