First post, by eL_PuSHeR
After selecting language, game exits complaining there isn't enough memory. MEM command shows:
    4.89 KiB
Reply 4 of 14, by Set
Qbix, can you explain how have you success in making pyscho pinball running in dosbox 0.60 ? For me it's not working ... after I've launched the game nothing happens immediatly but after 30s I have this error :
INT:Gate DPL<CPL
If I try to disable dpmi in dosbox.conf I have his error :
Unhandled CPU Opcode
Reply 6 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
Okay running it without dpmi is only possible in the next version of dosbox.
running with dpmi seems to go allright.
Games just starts up and runs.
Pet: maybe a corrupted version somehow ? (I ran at 3000 cycles and 16)
Water flows down the stream
Reply 10 of 14, by Set
I've the default setting for the sound :
sblaster=true
base=220
irq=7
dma=1
sbrate=22050
adlib=true
adlibrate=22050
cms=false
cmsrate=22050
🙁 The game runs on Win Xp but at low speed and with dosbox it's worse ...
An idea ?
Reply 13 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
Darkstar wrote:
You should check which versions of Dos/4GW you have... You can get other (older) versions of it here: http://dark-star.homeftp.o […]
http://dark-star.homeftp.org/dos4gw.html
--Darkstar
showthread.php?s=&threadid=214
might have even more.
