Game speed problem
First post, by dodgydave
I've read through various threads, guides and the manual, but I can't seem to change the number of cycles or the frameskip? I've done as stated (CTRL-F7/CTRL-F8/CTRL-F11/CTRL-F12 etc.) but nothing happens.
Few points which you may need to know/bring up:
1. I haven't remapped any keys.
2. I'm running Windows Vista (i've also tried running Dosbox as an Administrator)
3. I'm using Dosbox 0.74
Any help would be greatly appreciated.
Reply 1 of 14, by robertmo
where have you got dosbox from?
what are your PC specifications?
post content of "DOSBox Status Window" (in Windows: right click on its title bar -> edit)
enclose your dosbox's config file
Reply 2 of 14, by dodgydave
Dosbox downloaded from the "Windows" link here: http://www.dosbox.com/download.php?main=1
System spec:
Windows Vista Home Premium 64
AMD Phenom II x4 945 3ghz
8gb RAM
nVidia Geforce 9600GT 1gb RAM
Dosbox Status Window:
DOSBox version 0.74
Copyright 2002-2010 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file C:\Users\Dave\AppData\Local\DOSBox\dosbox-0.74.conf
Memory sizes above 31 MB are NOT recommended.
Stick with the default values unless you are absolutely certain.
MIDI:Opened device:win32
Config file is attached.
If you need any more info, let me know. Thanks for the help.
Reply 3 of 14, by robertmo
do other dosbox's shortcuts work? check them all and tell results
Reply 4 of 14, by dodgydave
Nope, none of the CTRL+"button" combinations seem to work. I initially thought that the keys had been remapped some how, so I tried CTRL+F1 to change them, nothing happened. I've also used the Reset KeyMapper.bat in case something had gone wrong, still the same result as before though.
Reply 5 of 14, by robertmo
check manual for windib
Reply 6 of 14, by dodgydave
Just tried that, still no luck. My Shift+"button" all work, just the CTRL+"button" that aren't. Also checked the thread shown in the manual, I don't have an extra devices. I've just got a standard PS/2 keyboard under (Keyboard) and a USB wheel mouse (under Human Interface Devices).
Reply 7 of 14, by robertmo
does ctrl work in windows? try ctrl-alt-del
Reply 8 of 14, by dodgydave
Yep, it works fine in Windows.
Just tested something that seems odd, which may be of help. In Dosbox if I use CTRL+(any letter) it brings up strangle symbols (smiley faces, "playing card suits" - heart, club, diamond, spade etc.), whereas in a command prompt it shows an "up" arrow plus the letter pressed.
Reply 9 of 14, by dodgydave
I don't think it's the CTRL button that's the problem. I was playing Wing Commander 4 earlier and none of the "F" buttons worked.
Reply 10 of 14, by robertmo
you said alt-f shortcuts worked, so once again:
Reply 11 of 14, by dodgydave
Alt-Pause and Alt-Enter both work as they should. Alt-F12 nothing happens.
Reply 12 of 14, by robertmo
do f keys work in windows?
Reply 13 of 14, by dodgydave
I am officially an idiot. The F keys weren't working in Windows either. A quick look at the Microsoft website mentioned a F Lock key on the keyboard (I didn't even know such a thing existed)... once I pressed it they all work, including in Dosbox.
Sorry for wasting your time, but thanks for all the help.
