Multiple Monitor Control
First post, by Yushatak
DOSBox should be capable of going fullscreen on any monitor instead of only the primary one.
Example scenario: You have dual LCDs, one 4:3 and one 16:9. You want to play a DOS game fullscreen and want it on the 4:3 monitor, but it's your secondary. You can swap primaries, run it, and then swap back, but this is tedious. At that point you may as well be swapping cables and having one monitor.
My scenario: I prefer CRTs for DOS gaming - they scale low resolutions beautifully in such a way that LCDs simply can't seem to replicate. I am easily able to stick a CRT on my computer as my second monitor, but I would really only be using it for DOSBox. It would be nice if I could set Monitor=1 in my DOSBox config and have DOSBox always open on monitor 2 in fullscreen mode that way.
I realize that this is also a question of SDL, but I'm not aware what restrictions SDL places on you in this regard, so forgive me if this isn't within the realm of possibility without SDL being modified or updated first.
Another thing that would make my life easier: I'd like to have the capability (as one does with a VM) to assign a device to DOSBox and DOSBox alone. I.e., I hook up a PS/2 keyboard and mouse, and a USB keyboard and mouse. I use the USB pair on Windows and set up DOSBox to only respond to the PS/2 set and to take over from Windows receiving on it to boot. This way one can operate DOSBox like another - separate - workstation.
Reply 1 of 17, by wd
Rank DOSBox Author
DOSBox Author
Assure that SDL 1.2 is capable of that and if so, feel free to post patches.
Reply 2 of 17, by Yushatak
Apparently SDL 1.3 can definitely do it (http://old.nabble.com/fullscreen-video-on-2nd … td27200533.html), but not 1.2. However, I can't submit a patch because I don't code in C/C++, not yet anywho. If I could I would have just made some kind of personal hacked build by now.
"You instead need use SDL 1.3 (not implemented on 1.2) and call the SDL_SelectVideoDisplay(index_of_mmonitor) (usually 0 for first monitor and 1 for second) so you can direct your SDL work output on your prefered screen (fullscreen or not)."
Is it possible to build DOSBox against SDL 1.3? If so, even I might be able to manage a patch of that simplicity, who knows.
What of my other idea, the dedicated keyboard/mouse one? I imagine it will probably never happen in the main build, right?
Reply 3 of 17, by wd
Rank DOSBox Author
DOSBox Author
There you are, one main point of SDL 1.3 (besides ripping off a lot of useful things)
was multi monitor/different output handling support. DOSBox uses SDL 1.2.
Not without large modifications because some "subtle" things in the keyboard
and output handling have been changed. But maybe you get a little further on this
than me.
As already stated, check if SDL is capable of doing this.
Reply 4 of 17, by Yushatak
I can't get SDL 1.3 to "make install", so I tried putting the include files and the dll file where they should be manually according to errors and directions and it won't detect SDL.
What's the proper procedure to get SDL "seen"?
Reply 5 of 17, by wd
Rank DOSBox Author
DOSBox Author
As I said dosbox uses SDL 1.2 and since SDL 1.3 is completely different in
several aspects you'll have to rewrite/adapt several things.
Reply 6 of 17, by Yushatak
Well I expected it to throw errors or refuse to compile DOSBox, I can't even get DOSBox to ./configure because of it not detecting the presence of SDL - SDL refused to make install, meaning that SDL is kinda wonky all on it's own before bringing DOSBox into the equation at all. Perhaps we need to just wait until SDL 1.3 has a stable release..?
Reply 7 of 17, by wd
Rank DOSBox Author
DOSBox Author
Yes but it will, i repeat, NOT work.
Reply 8 of 17, by Yushatak
I'm not a fool, I realize that at best you'd get an uncompilable mess, but at least I could give it a go then. As it stands there's not even anything to edit, it just "doesn't see SDL"..
Anyway I'll revisit this when SDL 1.3 goes stable and try again.
Reply 9 of 17, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You could mess with the configure script and then you could try to throw in some compatibilty header sdl 1.3 has that allows 1.2x apps to run under 1.3... But when you go the compatibility header way it probably, in wd words, won't work 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 10 of 17, by Yushatak
According to my latest research on the matter there is a "compatibility mode" API in SDL 1.3 to allow SDL 1.2 code to remain unmodified. I haven't been able to find much documentation on it, but if I understand right DOSBox should actually be able to build just fine with SDL 1.3 provided we could get it to detect SDL at all, and get SDL 1.3 using this "compatibility mode".
Worth noting that this is slower than using the SDL 1.3 native API, but on most machines that's kinda irrelevant as it's quick as hell as-is.
Reply 11 of 17, by wd
Rank DOSBox Author
DOSBox Author
Uhm yes of course, as Dominus says this is intentional because it is not compatible.
And of course there IS something to edit.
Yes it will BUILD but not WORK.
Reply 12 of 17, by Dominus
DOSBox Moderator
It's not like I didn't mention the compatibilty mode in my previous post... Could have saved yourself some research...
Reply 13 of 17, by Yushatak
Hah. Didn't see that.. 🤣
Reply 14 of 17, by PunkMaister
So in short Dosbox is incapable of displaying a full screen on a secondary display period end of story...
Reply 15 of 17, by Dominus
DOSBox Moderator
Yes, thanks for writing that after TWO years.
I wonder why you felt the need to necropost and not even adding something useful...
Reply 16 of 17, by DoxxedBoxman
But, PunkMaister's comment was useful.
It summarized the entire thread and you confirmed.
Saved me the investment of reading all it.
6 years baby!
