First post, by ratfink
I just fitted a new [as in "unused"] 80mm Speeze aluminium-but-copper-cored heat sink and fan to my Athlon XP. Damn sight quieter than the Qtec solid copper heat sink and 60mm fan I used before, and 3 degrees cooler.
But there's a high-pitched noise coming from the fan, a bit like an old CRT makes. Can the fan be lubricated and what should I use? Choices seem to be graphite powder, silicone oil [like for musical instruments or shavers], or good old 3-in-1 household oil.
