First post, by Olek78
Olek78
Offline
Hello everybody,
After I start the dosbox via a frontend ( my own implementation ). Can
I get access to the console where I can type in?
I use Java as programming language and there I can get an output-stream of the dosbox-process but if I try to send some command like e.G. "DIR"
nothing happend.
I guess I get only the output-stream of the DosBox Status Window. Am I wrong?
Regards,
Olek
