First post, by rpjacks
I am sorry if this is already covered, I am a new user and having no luck in finding any answers to my specific problem.
I used to play a game called Rise and Decline of the Third Reich, normally shortened to Third Reich. I played this on my old dos computer, my win 95 and 98 systems with no problems. I had a winxp home computer which allowed me to use the program, but it crashed alot and I think I had to do some adjustments to make it work.
I now want to run it in my windows vista system, I no longer have the previously mentioned systems. I found it in the compatibility list which said it is supported.
When I now try to use it through dosbox, whether through d fend reloaded or on it's own, I get the following error
DOS/4GW fatal error (1313): can't resolve external references
I have Google searched for this error with no luck, and replacing my dos4gw exe did not help. I can not find the Third Reich program in the preconfigured listing in d fend reloaded, but use generic dos compatibility for it.
Any help would be greatly appreciated. I really don't know much about computers and just use mine for entertaining my brain.
And in this moment, I will not run, it is my place to stand.
Reply 2 of 2, by rpjacks
Thanks for your speedy reply, however I am running into an even larger problem now.
The downloaded file says that it is a windows file (apparently old pre 95) so it won't install under dosbox. I tried under d fend reloaded and failed too.
I may have bitten moe than I can chew on this request
