First post, by Irisse
Hello,
i need to mount a z: unit to run a specific aplication, but DOSBox mounts itself in that unit.
How can i change the default unit in wich dosbox is mounted?
Thank you very much.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you change the sourcecode of dosbox or just have bad luck.
What kind of application requires it ? The only game I know that requires it is the cracked version of Z.
Water flows down the stream
Reply 2 of 3, by OSH
Maybe VMWare? But under VMware it's possible to change mapped drive letter.
Reply 3 of 3, by Irisse
Thank you very much for so a quick answer.
It was not a game, just foxbase, I have some old programs working with it.
The problem was that i don't have the instalation program, just copy it, and newer versions i could found weren't 100% compatible, and the program was not able to find the correct path.
I found the config file and edited it changing in this way the default path, so i could solve the problem.
Thank you another time for your answer and for so great program, i'm going to rescue some old games too (starting with double dragon).
Kisses.
