Doskutsu
First post, by leileilol
Cave Story had many ports (Linux, Mac, PSP) but none for DOS? That's just blasphemy.
What could be done in a port:
- Allowing 320x240x8 by color remapping to an optimally generated palette. The hard part is giving Doctor its own palette to calculate a red fade in. This would be faster than running in the game's native resolution of 640x480x16 (2x pixel scale, with sharp fonts)
- Using a fixed pixel font instead of interfacing with truetype or freetype
- Option of OPL-3 Org? The music code stands between running the game on 486 class machines... or at least a lower sampling rate option.
As of now, the game doesn't function under Windows 95 or even HXDOS. It relies on some Windows 98 shell dependency for a no good reason (it doesn't even touch "My Documents")
No, I can't port it - wish I knew how.
Reply 1 of 3, by robertmo
It works if you install IE4.0
(Although after using english translation patch game doesn't work in any win9x for me (at least not in dosbox 😉 )
Anyway the game works fine (even with enghish translation) in winxp and 7 so why do you want dos ver?
Reply 2 of 3, by Jorpho
Why indeed? I reckon some of the graphical effects would require a pretty powerful machine even in DOS.
I seem to recall someone was trying to re-implement the engine in an open-source project, but I doubt it got anywhere.
Also, wasn't the PSP port unauthorized and canceled?
Reply 3 of 3, by CrisGer
here are all the versions including a PSP port....
http://www.cavestory.org/downloads_1.php
this is SkyeWelse's tribute site and has very recent Site Updates October 20, 2010
Admin
3D Worlds and Game Developers Group Linkedin
http://3dworldandgamedevelopers.blogspot.com/
