DOS Games on Windows 7
First post, by EmHe
I'm trying to run a DOS game on my PC with Windows 7.
I have installed DOSBox 0.74 and tried to run my game with that.
I have opened DOSBox and did what wikipedia told me to do, but I'm stuck at the last instruction.
I have also tried tdcga.com and tdcga.bat.
See attachment..
Can anyone please help me?
P.S. Can you please reply in easy english? I'm not that good in English.
Reply 1 of 10, by wd
Rank DOSBox Author
DOSBox Author
type "dir"
Reply 2 of 10, by EmHe
Okee, and then?
Reply 3 of 10, by Jorpho
If you can't figure it out yourself from there, post a screenshot of what you get after typing "dir" and a solution should present itself.
Reply 4 of 10, by EmHe
So, what should I do now?
Reply 5 of 10, by SKARDAVNELNATE
Change directory (cd) to SUPAPLEX. Is tdcga.com or tdcga.bat located in that directory?
Reply 6 of 10, by EmHe
I'm not sure what you mean by that..
The first thing you said worked.
Reply 7 of 10, by EmHe
Reply 8 of 10, by Jorpho
Oh dear. Is this the guide you're following?
http://www.dosbox.com/wiki/index.php?title=Ba … ation_of_DosBox
For starts, that is not Wikipedia. That is the DOSBox Wiki. (There are many, many websites out there that use the same software as Wikipedia.)
Secondly, that is an example for running a specific game, Test Drive. You are not trying to run Test Drive, so of course if you follow the instructions exactly, it won't work! Please see the 60 Seconds Guide to DOSBox for more generalized instructions.
Reply 9 of 10, by EmHe
Thanks for telling me I'm doing it wrong.
I found my way, so I can play the game now!
Many many thanks!!!
[/i]
Reply 10 of 10, by Neville
If you're not versed on the usage of MS-DOS, maybe yopu'll be better off using a frontend to launch your DOS programs. With DBGL or D-Fend Reloaded all you have to do is point towards the excutable (that would be SUPAPLEX.EXE here) and be done, because most programs will work with default settings.
