First post, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I'm getting an exception when executing a CONFIG command with any parameter specified. I traced it to a FOR instruction in GetParameterFromList()
for(Bitu i = 0; params[i]!=""; i++) {
The loop is not ending on the last element, so it tries to process past the end of the array. I thought the empty string might be an issue, but changing the last element to some string value like "endlist" and testing for that still doesn't end the loop. Maybe a bug in the version of GCC I'm using, but this works:
for(Bitu i = 0; strlen(params[i])>0; i++) {
Reply 2 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I use these compile flags for testing:
CXXFLAGS="-s -O2 -fomit-frame-pointer -ffast-math -march=i586 -mtune=i686"
Seems fairly conservative, and nothing in there sticks out as being problematic. Using more optimized flags for my specific processor type doesn't help.
Hmm, strcmp() works but == and != are not working for the params array elements at all, either in the FOR condition or anywhere in the function. Is it supposed to be that way, or a problem with GCC?
