First post, by lucky7456969
The udp is setup, no ethernet addr
I've loaded in ne2000 for megabuild5 with
ne2000 0x60 3 0x300
and after that, I loaded in
winpkt 0x60
Then inside windows,
I use twinsock. IP is my computer addr, DNS is my ISP's DNS
Enabled SLIP.
But ethernet tracking says packets are trying to deliver from
0:0:0:0:0:0:0:0 => 0:0:0:0:0:0:0:0
127.6.5.12 => DNS server
where 127.6.5.12 is a made-up IP address. I have this valid
it seems to be accessing the wrong protocol. What can I do?
I am using win3.1 and netscape 3.0.
Thanks
Reply 1 of 3, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
What does the DOSBox status window say?
1+1=10
Reply 2 of 3, by lucky7456969
No, it doesnt say anything
Reply 3 of 3, by lucky7456969
Recently, I have setup a router that dosbox can use it as a gateway
But no matter how I try, there is no MAC address for my gateway on winsock.
Is this an architectural limitation?
Thanks
