First post, by keropi
Hiya!!!
I am searching (without luck 😐 ) for a DOS utility that can replace strings inside a text file...
something like this: awesomeutil.exe test.txt dog cat
so that awesomeutil opens test.txt finds the string "dog" and replaces it with "cat"
All I can find are some enhanced scripting methods that only work in win2k and above dos-box "termninals" ...
Any help will be greatly appreciated, thanks! 😊
Reply 1 of 9, by retro games 100
awesome~1.exe woof meow 😉
Reply 2 of 9, by Harekiet
Rank DOSBox Author
DOSBox Author
Find a set of djgpp converted unix tools that run in dos
Reply 3 of 9, by keropi
that was the easy part, but I am confused about what part of the djgpp does what I want 😢 😕
Reply 4 of 9, by 5u3
Reply 6 of 9, by 5u3
Sorry for the nerd joke, but I couldn't resist... 😉
grep, awk and sed are useful tools for searching/replacing strings in files.
Reply 7 of 9, by keropi
🤣 nice, let's see IF I can work with them , since on wikipedia I seeonly sed might do the job but looks complicated 🤑 🤑 🤑
Reply 8 of 9, by Yushatak
If you can find Win32 console utilities to do what you want, you can use them in DOS (provided you've got a 32-bit CPU to work with) using Japheth's HX extender.
Reply 9 of 9, by keropi
I am only interested in a dos-only solution that does not need any kind of extenders... I am reading on sed and it's DOS versions here: http://www.cornerstonemag.com/sed/ but frankly it seems too much complicated for the small/simple use I plan for it... line buffers , operations and all are great , but for more complex jobs...
edit:
I think I found what I need , it is called MiniTrue and from the manual it looks promising:
Example 1 - The original MiniTrue
mtr -rnw * - Eastasia = Eurasia
This will replace all instances of "Eastasia" with "Eurasia" in all
files on the current drive. The -r option is necessary for scanning
to recurse through the subdirectories. The -n option will make
replacements automatically, and the -w option will only find whole
words
edit2: complete success! minitrue 2.02b does EXACTLY and easily the job 😁 anyone interested can grab it here: http://www.idiotsdelight.net/minitrue/
thanks for all the suggestions/pointers/help , if it wasn's for the djgpp/grer/sed/xyz stuff I would have never found about minitrue 😊
