Help With Game
First post, by grog1961
I'm trying to get my Hyper 3dPinball to work but I'm having
problems. I use to have it installed before I had to get my hard drive replaced but I can't get it to work now.
I followed all the tutorials and do everything it says but I get a message saying no cd drives present when I'm finished.
I even installed an older version of DosBox that the website said works with Hyper 3dPinball but it still doesn't work.
Can anyone help with this????
Reply 1 of 12, by Gamecollector
Tested.
mount d j:\ -t cdrom (j is my real cd-drive)
d:
install
Installed w/o errors, DOS4GW error (divide by zero) in the first run.
Looks like sound auto-detection is broken.
Setsound.bat, GUS + MPU401 are set.
3dpinbal.exe - no errors, game run smoothly... 800x600, cd music etc...
Dosbox settings used - svga_s3, overlay, aspect=true, gus=true, io240 dma3 irq5.
Reply 2 of 12, by grog1961
I'm not too familiar with DOS BOX so I don't really understand what you
are trying to tell me.
I'll give it a try and see if I can figure it out.
Reply 3 of 12, by grog1961
I tried what you said but after I typed in install it came up with the below message: Copying error: UVCONFIG.EXE D:\UVCONFIG.EXE
Reply 4 of 12, by SKARDAVNELNATE
Did you mount a C drive?
Reply 5 of 12, by grog1961
No! Do I have to mount both????
Reply 6 of 12, by grog1961
Can someone please give me easy step by step instructions on how to do this????
Reply 8 of 12, by grog1961
I get the game to run using the link you gave me but I can't edit the CONFIG
file correctly so the game will run when I click run DOSBox
Reply 9 of 12, by grog1961
I'd like to add that after editing the CONFIG file the game starts to load but then
I get a COULD NOT INSTALL UNIVBE" message.
The game works the first time I install it but when I close the game down and
try to play again that above message comes up
Reply 10 of 12, by grog1961
I guess every time I want to play this game I'll just reconfigure DOSBOX again and reinstall the game. I looked for my UNIVBE problem in a search engine but I saw nothing that helped.
I even deleted the file out of the game directory but I still got this message.
Reply 11 of 12, by grog1961
Someone told me to try the D-Fend-Reloaded program.
I don't know what I did to get the game to run now but after installing
that program and guessing on what to do the game now works!!!!
HURRAY!!!!!
Reply 12 of 12, by IIGS_User
I guess you need to use the same mounting commands as given at the first installation time.
D-Fend Rel. was *one* answer to this problem,
using a specialized configuration file another. 😀
Klimawandel.
