First post, by KentRieske
I developed and market engineering software in MS-DOS format using BALERXE spreadsheet compiler. It runs nicely in Windows XP using Aladdin (SafeNet) copy protection with a USB Hardlock Key as the dongle. My unprotected applications run about the same in DOSBox 0.74 on Windows 7 32-bit machines but DOSBox prevents the Aladdin copy protection software from finding the Hardlock Key dongle in the USB port. Aladdin does not have a driver in DOS format for finding the USB port. I am still testing and have a new 64-bit computer on order.
QUESTION:
Who are the companies that have copy protection for MS-DOS applications that work in DOSBox 0.74?
Is the DOSBox crew working on USB drivers, or such, that will allow my copy protected application to run? What is the expected time when applications will be able to use the USB ports?
Thanks,
Kent
