First post, by DungeonMaster2
Hi,
i installed Dungeon Master II on DosBox 0.74 and DosBox 0.72 but no one works with it.
Last time installed DM2 was when i had a Windows XP System, now i got Windows 7, is this a problem...?
The game runs , the music (midi) runs but the sound effects doesnt work ingame.
But in the setup program when i click on "test digital" it works! why not in the game???
i tried Soundblaster, Soundblaster Pro and Soundblaster 16
all worked in setup program but not ingame.
i also tried running Dosbox in 98, 2000 and XP mode with different options and admin rights but nothing worked.
i tried my old original CD (german version) and a downloaded english version...
I hope anyone can help me...
Reply 1 of 2, by DungeonMaster2
problem solved!
i changed the DeviceIRQ from 5 to 7 in the skull.cfg and setup.ini
and also select 7 for digital DeviceIRQ in the Setup-program.
Reply 2 of 2, by DataPro
I want to know if someone has succeed to make MIDI music working with something other than FM synth in this game.
I tried to redirect sound to MIDI Out or Wavetable without any success.
I got an ISA AWE64 (A220 I5 D1 H5 P330 E620 T6) with a real Roland MT-32 and a real Roland SC-88 linked to MIDI out (P330)
HP Vectra 562 P166Mhz/256Ko L2 cache/Triton 430FX - 112Mo RAM - 2x 32Go+64Go CF Card - Matrox G2 8Mo - SB AWE64 ISA (PnP) + Roland MT-32 & M-GS64 (SC-88) & JV-1010 - Nec USB 2.0 PCI - Promise Ultra100 TX2 - Hama multicard reader
