First post, by dosquest
I saw the suggestion thread but I would like a list of features that will be in the next version.
Reply 1 of 9, by IIGS_User
I think they'll be listed at its time.
Klimawandel.
Reply 3 of 9, by dosquest
Well, I was wondering like any new sound cards added and also percent wise will dosbox be able to play now like what 91% of most of the games?
Reply 4 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
i will post the new things on the homepage when there is a new release.
You can read the changes to dosbox at
http://source.dosbox.com/dosboxsvn.txt
If you read the messages there closely then you can guess what will be in the next version.
Water flows down the stream
Reply 5 of 9, by Barry_Purplelips
There's this nasty problem with certain tunes played through OPL, like that from Doom2's map12. It basically sounds like some synth piano replacing a drum line, creating dissonance, but it could be something else, however, I have a real sb16 to compare it against and it's definitely broken regardless of the config.
Question is, I couldn't find anything relevant to the problem in the svn changelog, but maybe it's been addressed under a misleading name? this has been an issue forever so... 🤐
Reply 6 of 9, by wd
Rank DOSBox Author
DOSBox Author
Whoa you could at least start what settings you used (oplemu especially)
and which dosbox version works fine, which doesn't.
Reply 7 of 9, by Barry_Purplelips
Well, I stand for "regardless of the config" and no version of DosBox actaully gets it right, at least not on WinXP. Currently I have the latest stable version installed, plus I've been unable to use the svn builds for a while since I'm missing some libraries which are not supplied.
You should be able to reproduce this with the default settings.
Reply 8 of 9, by wd
Rank DOSBox Author
DOSBox Author
Well then post a full report in an own thread, including the opl settings you tried.
Chances are rather low to fix something like this without digital captures of
played-back opl streams.
Reply 9 of 9, by Barry_Purplelips
God, I thought this was a known issue. I'll start a thread for this.
