First post, by retro games 100
- l33t
It's a SYL8884PCI-EIO mobo, and it works with an AMD 5x86 P75 CPU. The documented bus jumpers go up to 50 MHz. I tried the P75 (133 MHz) chip @ 40 FSB, and it worked fine @ 160 MHz. The board accepts EDO RAM. I put one stick of 32 MB in to the mobo. The voltage options are 3.3, 3.47, 3.6, 4, and 5. There are 3 jumpers on the mobo for the bus speed, and their documented values are 25, 33, 40 and 50. I wonder if I should experiment with undocumented jumper settings, to see if I can get the bus to run at 60 FSB? The only problem with this idea is that I cannot see a documented option to set the AMD 5x86 P75 chip to a lower multi of 3x.
I also set the mobo's BIOS timings to their most aggressive settings possible, and everything worked including Quake time demo - results are below. Inside the mouse driven AMI BIOS set up area, there is an option that says "PCICLK-to-ISA SYSCLK Divisor", and its possible values are PCICLK/2, PCICLK/3 and PCICLK/4. What does this mean? The board must be baby AT, because its measurements are 180cm x 220cm (approx). The manual (paper sheet!) mentions a PS/2 port, but sadly there isn't one on my mobo.
Benchies:
3DBench = 0.00 ?
3DBench2 = 94.3
Quake software mode, screen size 2 notches below max = 17.1 fps
Speedsys -
