Fallout 1
First post, by Phulax
Fallout - Interplay (1997)
Tested By: Tag2015
runnable - playable - supported
DOSBox version: 0.72 (supported)
I have the latest version 0.74 but when I try to run FO1 through DOSBox I get this message: "This is a Windows NT windowed executable."
I have Win7 & am successfully running 2 other old games on DOSBox.
FO1 can be run without DOSBox on Win 7 but the graphics are not good.
Any suggestions?
Reply 1 of 45, by leileilol
simple: DON'T RUN THE WINDOWS VERSION
If only error messages gave people clues! If only!
Reply 2 of 45, by Phulax
The Windoes version is the only one I have - or am aware of.
Reply 3 of 45, by leileilol
The DOS version comes on the same disc. Check your disc and run the DOS-based installer on it.
Reply 4 of 45, by Phulax
TY for your help but unfortunatelyo Win 7 won't allow it to start.
Reply 5 of 45, by leileilol
DON'T USE WINDOWS 7 TO RUN THE DOS INSTALLER!
Use DOSBox to install the game.
Reply 6 of 45, by Phulax
OK TY - I'll have to do some research on the DOSBox site as how to do that.
Reply 7 of 45, by Phulax
Please forgive my ignorance, but although I can see how to mount the D: drive cd rom where my FO CD is - "Install" brings up the install screen ok but then how do I direct it back to drive C: as otherwise the install screen can't find a drive big enough to install to. How do I make C:\Oldgames available?
Reply 8 of 45, by SKARDAVNELNATE
See the freesize option in the readme file.
Reply 9 of 45, by Hazekel
Actually, if you run the Windows version with Windows95 compatibility on, there should not be any graphics glitches. That may be simplest for you.
If not, it should work in DOSBOX but there is a learning curve. Read the DOSBOX instructions or maybe the new Frontend tool.
Reply 11 of 45, by Phulax
Thanx for all your replies. It does run as you say under the Win 95 compatibility & I will just have to put up with the distorted video. 😀
Reply 12 of 45, by bloodbat
If by distorted you mean it displays the wrong colours, there's a registry fix you can do.
Reply 13 of 45, by HunterZ
I'm curious as to what the registry fix is, as the only thing I know that works is to kill Windows explorer and/or dwm (don't remember which).
Reply 14 of 45, by Qbix
Rank DOSBox Author
DOSBox Author
think there was a post on vogons about it.
Water flows down the stream
Reply 15 of 45, by bloodbat
Well, you could kill explorer, or, for a more elegant solution, suspend it with pssuspend from Sysinternals, but to get the registry fix going you need to run Fallout 1, exit, then, before running anything else that hooks on directdraw, look at HKLM\SOFTWARE\Microsoft\Directdraw\MostRecentApplication and note the ID and Name values; then make a new key under HKLM\SOFTWARE\Microsoft\Directdraw\Compatibility, name it with you want, but fallout1 would be appropiate 😜
Inside that key, create 3 new values:
A Binary Value called "Flags" (without the quotes) and fill that with this: 00 08 00 00, then you create another binary key called "ID" and fill it with the ID value you noted from the MostRecentApp. I mentioned above, and finally, a String value called Name, to be filled with the name you noted from above.
This works for a number of games incluiding Starcraft, Take No Prisoners and MageSlayer.
Keep in mind that, if you're running a 64 bit version of Windows Vista/7, the values will be found under HKLM\SOFTWARE\Wow6432Node\Microsoft\DirectDraw and so on
Reply 17 of 45, by Phulax
I opened up the DOS version of FO1 in my XP laptop, installed it to a flashdrive, then copied into my "Oldgames" file in my Windows 7 puter for DOSBox to open up but it told me it could not "find" the master datafile, which is ridiculous because the file is "hiding" there in plain sight. Also it told me to "make sure the Fallout CD is in the drive..."{???}
Should I have installed the DOS version of fallout on my XP puter via DOSBox & then copied to the flashdrive, etc? Would that have made a difference?
I have a real love-hate relationship going with my Windows 7 puter!
Reply 18 of 45, by eL_PuSHeR
Edit the config file to point master.dat to its current location.
Reply 19 of 45, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I see this is where the other thread stems from... You should have installed the DOS version in DOSBox on your Windows 7 PC. The guide I mentioned twice now tells you how (and to not only mount the CD rom drive but also a c:\ drive in Dosbox...)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
