Dune 2 - need help!
First post, by sq303
Hello guys,
i`ve been trying to run this game on Windows 7 with dosbox 0.74, i`ve done like faq says, first create folder, than mounted, and when i`m typing "cd dune" it says "unable to change to: dune" so obviosuly i can`t go into this folder, actually any folder, what shall i do? thanks
Reply 2 of 14, by eL_PuSHeR
Or write down all commands used. I think you may have forgotten some step,
Reply 3 of 14, by SKARDAVNELNATE
sq303 wrote:
first create folder
Check.
sq303 wrote:
than mounted
Okay... Check.
Errr... what? How do you already have a Dune folder? You haven't installed that game yet.
Reply 4 of 14, by HunterZ
Be more specific about directory names and what's in them.
Reply 5 of 14, by sq303
Thanks for respond, here it is.
f87fa8be1310560emed.jpg[/list]
Reply 6 of 14, by sq303
commands are:
mount c c:\dune2
c:
cd dune2 and says (unable to change)
what you mean by `install a game` there is a folder with game, setup is for sound and mouse, thats it
Reply 7 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You didn't understand the concept of mounting.
Create a folder c:\dosgames
put the dune2 folder in this folder
mount c c:\dosgames
1+1=10
Reply 8 of 14, by HunterZ
sq303 wrote:
commands are: […]
commands are:
mount c c:\dune2
c:
That's because you mounted c:\dune2 as the root of the virtual c drive inside of DOSBox. If you want the game to show up in a dune2 subdirectory of the virtual c:\ drive then you should be putting your games in something like c:\dosgames\dune2 on your real hard drive and then mounting c:\dosgames to the virtual c drive.
Edit: Doh, h-a-l-9000 beat me to it 😀
Reply 9 of 14, by sq303
well, i didn`t 😀 so i`m here
ok its done
c:\dosbox\dune2
mount c c:\dosbox
than c:
cd dosbox - unable to change
Reply 10 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
cd dune2, not cd dosbox
also type dir to see what you can cd to
1+1=10
Reply 11 of 14, by sq303
sorry dosgames
still the same - unable to change to: dosgames
Reply 12 of 14, by sq303
ok works !!!!!!
thanks for patience 😉
cheers mate
just one more question, how can play on full screen?
Reply 13 of 14, by HunterZ
alt+enter, or edit the dosbox options to set fullscreen=true
Reply 14 of 14, by sq303
excellent, thank you kindly
