First post, by Bambo
I've got a problem with The Elder Scrolls Chapter One: Arena (CD Version)
This game is quite resorce demanding - when I want to play with maximal view distance I need cycles == max (or at least ~50.000) for smooth gameplay
But when I play above 12.000 cycles (12.000 cycles == 486DX 33 Mhz according to Norton Sysinfo 8.0) the game gets some serious glitches
(Super fast animations & running speed, hyper responsive menues etc.)
This is quite a dilemma: When I set it to a fast CPU, the game glitches but when I set it to 12.000 I get serious slowdowns (especially inside certain buildings) even on minimal viewing distance!
System:
Core2Duo 8200
2 GB RAM
Win 7 64bit
Radeon 4850 512MB VRAM
Dosbox 0.74
Resolution 1600x1200 @ ddraw (it the same with "original" @ surface)
core=dynamic
cputype=auto
cycles=12000
etc.
Reply 1 of 4, by catchaserguns
When playing the game press esc. to the save and load screen. Yhere is a detail bar on it. Lower the detail and things will get better. Thats what I had to do.
Reply 2 of 4, by greywolf
Have you tried "output=overlay"?
For my Arena configuration, this makes a difference, compared to "output=surface". With "cycles=25000" and details on max, Arena runs quite smoothly.
Regarding hardware and OS, I'm using a 4GB RAM Vista PC with resolution 1280x1024 and a Radeon 3750.
Reply 3 of 4, by leileilol
Well, the problem is here:
Bethesda
/me RUNS FOR THE HILLS
Try setting cputype to pentium_slow, see if that helps somewhat
long live PCem
Reply 4 of 4, by greywolf
Here a quote from the 1.06 patch notes (i.e. this is independant of DOSBOX):
"A Pentium slowdown has been included in the patch. To slow down game play for a Pentium, type:
arena -delay:#
at the DOS prompt, where # is an integer between 1 and 9. 1 causes the
least delay, 9 causes the most delay. We recommend 4 as a good speed.
If, after starting the game on your Pentium using this feature, you find
the speed still is not right, you may adjust the delay using the + and -
keys."
I'm not using the delay parameter myself as I'm happy with the performance of Arena, but you may wish to experiment with it.
If you do - let's know how it works.
