First post, by Warrior527
I just got Doxbox for my computer and been playing alot of my old dos games.
But I have a problem with Star Trek: JR. When I try to save a game, it says "Unable to save game. Disk must be full or read only"
My Disk has over 400GB free, and not read only.
Also Star Trek: 25th anniversary saved just fine. Please help.
Thanks
God bless
Dan
Reply 1 of 13, by leileilol
install the game first
Reply 2 of 13, by Warrior527
I did, the games runs but does not save.
God bless
Dan
Reply 3 of 13, by Gamecollector
Or try to mount your disk c with -freesize 500 parameter. DosBox do not like the 512+ Mb freesize.
Reply 4 of 13, by Warrior527
The freesize didn't work, or I might be doing it wrong, can you give me the complete path line for the freesize mounting.
Thanks
God bless
Dan
Reply 5 of 13, by ADDiCT
Before you start aimlessly finddling around with parameters you don't understand, don't you think it'd make more sense to give us some more information so we can try to find out what's actually wrong? OS, DOSBox version, how was the game installed, etc. . The basics.
Satan bless
Reply 6 of 13, by Warrior527
My OS is: Windows XP (version 2002 with service pack 3)
DOS Box version is: 0.74
And I installed the game through DOS Box.
If you need more info let me know.
God bless
Dan
Reply 7 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
The mount lines when running the game would nice to know
Water flows down the stream
Reply 8 of 13, by Warrior527
Z:\>mount d d:\ -t cdrom
Z:\>mount c c:\intrplay\trek2
z:\>cd\
c:\trek2
Hope that helps.
God bless
Dan
Reply 9 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
mount c c:\intrplay
c:
cd trek2
trek2
Reply 10 of 13, by Warrior527
Qbix I tried your idea, but it didn't work. Do you have any other ideas?
God bless
Dan
Reply 11 of 13, by rcblanke
Reinstall the game in dosbox, and _keep the mounts the same_ when starting the game. Your trek2.cfg does no longer correspond to the virtual directory structure in dosbox, probably.
Reply 12 of 13, by HunterZ
Yes, it's important to use the same mount commands for the virtual hard drive and CD-ROM every time you install and play, so that the virtual paths don't change.
I highly recommend making a folder on your real hard drive to use as the root of the virtual/mounted c:\ drive in DOSBox. Personally I use "c:\users\public\games\dos", which results in games installing themselves to things like c:\users\public\games\dos\intrplay\trek2 on the real hard drive and c:\intrplay\trek2 in DOSBox.
Reply 13 of 13, by Warrior527
Thank you everyone for your help, but I got the game working. Rcblanke your idea to reinstall and keep the mounts the same worked. Thanks again everyone. It is nice to see a forum community so active.
God bless
Dan
