First post, by soundblastermusic
Hi,
I have installed carmageddon using dosbox and it's running fine (in low resolution mode).
However I wanted to play the high resolution mode by running the command "carma -hires" at the prompt. After increasing the amount of RAM DOSbox uses to 24 MB (carmageddon hires needs at least 24 MB to run) the game successfully runs but I have a problem I can't fix: it runs at a very slow framerate, too slow to be able to play the game.
I'm using a Pentium 4 Hyper-Threading 3.00 Ghz. When I modify the "core", "cycles", "output", ... settings of DOSBox to try to have a better framerate, nothing really changes to the framerate. So I can't make it run faster whatever settings I change in the conf file of DOSBox.
Now my question is:
is my processor written above just too slow to run carmageddon in high resolution at an acceptable framerate (so I need a more modern CPU)
OR
is there a special configuration I have to set in the conf file of DOSBox to make carmageddon run smoothly in high resolution?
I hope somebody can help me with this problem and tell me what changes I have to make to the conf file to make it run faster!
Thanks
Reply 1 of 14, by mr_bigmouth_502
By today's standards, your processor is actually quite slow. To run Carmageddon in hi-res under DosBox, I'd suggest upgrading to something a little more modern. A cheap Core 2 Duo or Athlon II-based machine should do the trick. 😀
Reply 3 of 14, by wd
Rank DOSBox Author
DOSBox Author
Carmageddon is still very demanding (graphics output transfers), anybody tried the highres mode?
Reply 5 of 14, by wd
Rank DOSBox Author
DOSBox Author
That's SOOOOOOOOOOOOO wrong, not having Carmageddon is a sin 😉
Reply 7 of 14, by rfnagel
Just my two cents, I can't even get decent framerates using low-res mode; this on a P4 2.666GHz w/512MB RAM... but AFAIK, that's to be expected with Carma. (on my relatively lower class PC).
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 8 of 14, by bloodbat
Low res works fine for me, but I can't do high res because it's Max Pack.
Reply 9 of 14, by telanus
The stock-standard carmageddon hires here gives the following error:
Failure: DatafileStack type mismatch, wanted 2 got 2
Splat pack is running nicely
Reply 10 of 14, by shock__
Personally I found the best solution for Carmageddon is GliDOS + vdmsound
Runs nicely at a full framerate, gives you texture filtering and custom resolutions, already worked fine on my former desktop (AMD64-3500+ and GF6600GT), while the hires version under DOSBox was still crawling. Still has a few minor issues (backmirror + mini playfield on the map not working) but the game is still easily playable that way
Reply 11 of 14, by leileilol
My favorite solution to getting it working is using an actual Pentium II system 😀
Reply 12 of 14, by mr_bigmouth_502
I second this. 😁
Reply 13 of 14, by bloodbat
telanus wrote:
The stock-standard carmageddon hires here gives the following error: […]
That's the same error my Maxpack spews if using -hires...that the readme clearly states is not there:
"HIRES
Because of the 3DFX version there is no Hi-res support in the Max Pack"
Reply 14 of 14, by Myloch
I have a i7 860 and carma in hires software mode is still laggy.
For carmageddon in hires, better to use 3dfx patch.
I think it's game engine fault, it's not a dosbox problem.
I remember it was an insanely badly optimized engine.
