First post, by RaVeN-05
Can anyone write guide how to setup FUSION
http://www.emulators.com/download.htm
to run it under dosbox?
I need specially this way. FUSION + DOSBOX. only.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 1 of 8, by Jorpho
You do realize that whatever you can do in Fusion, you can probably do much, much better in Basilisk II, right?
There has been some discussion on the Emaculation.com forums about running Fusion in DOSBox.
http://www.emaculation.com/forum/viewtopic.php?t=6693
Reply 2 of 8, by leileilol
something tells me you want to play hexen mac on it
forget it, stick to basilisk and/or sheepshaver.
p.s. Fusion's so old, I used to pretend to have System 7 dualbooting on my PC with it back in the 90s 😀
Reply 3 of 8, by RaVeN-05
You right, but more that i want is record hexen mac music and wolf3d, dosbox can do it perfectly!!! Basilik or sheepshaver not, at least i cant find it feature, recording with "Wave recorder" or similar applications through my sound card is very bad way i get poor quality (((((
or did you know any MAC emulators that can make sound recordering?
P.S. leileilol, thanx for hexen beta =)
Reply 4 of 8, by Jorpho
You will probably have an easier time fixing whatever is wrong with recording things through your sound card than you will getting Hexen Mac running under Fusion running under DOSBox.
Reply 6 of 8, by Jorpho
And Fusion isn't necessarily very good for running Hexen, either. (I can't say for sure because it's certainly something I haven't tried, but I wouldn't count on it.)
You can elaborate more on your problems, if you like. What sound hardware are you using? And what application are you using to record from it? Are you sure you're recording off the right channel? (See http://forums.pcpitstop.com/index.php?/topic/ … hearstereo-mix/ or http://stream-recorder.com/forum/missing-soun … cord-t4876.html, for instance.)
Reply 8 of 8, by RaVeN-05
collector wrote:
If your problem is with your real hardware, running an emulator isn't going to fix it.
Its going to fix it, you don't know, i am always use this method.
Dosbox record sound in digital way, record everything that happens inside this program, i always get identetical sound, exactly same as i hear
