My retro setup.
First post, by dosquest
My setup is pentiumIII 500mhz 512mb ram ati rage pro (integrated) with 8mb video memory, the hard drive is a 800mb western digital. Sound card is a rockwell softmodem. The os is win95c. I'm looking for a cheap video card that will be capable of playing doom,quake and blood era games, any suggestions?
Reply 1 of 49, by Alphakilo470
If it's 500mhz, then your computer sounds new enough to have an AGP slot. If so, then you won't have much issues, pretty much any AGP card will run your old DOS games fine. If you're getting a PCI card, I'd say make sure it has at least 4mb of video ram. My personal preference for the video chipset is ATI and Matrox though on this forum, I hear a lot of positive remarks about S3 products as well.
My Gateway 2000 system has an 8mb ATI Rage video card which seems to run with anything that supports Mach64 and runs all my old games like a charm.
Since you're running a GUI OS, I'd shy away from anything with less than 4mb. Anything with less memory will force you to pick between low resolution or low colors when in Windows.
Reply 2 of 49, by sprcorreia
What card do you have right now? These games don't require a beast card to run properly...
Reply 3 of 49, by dosquest
Mine is a dell optiplex with ati rage pro 8mb! where did you get the drivers for it because I'm only able to display in 16bit right now (fresh install)
Reply 4 of 49, by sprcorreia
dosquest wrote:
Mine is a gateway with ati rage pro! where did you get the drivers for it because I'm only able to display in 16bit right now (fresh install)
I believe that card is more than enough for those games... Do you have issues running them?
Reply 5 of 49, by dosquest
It says "this game requires 256 color please adjust your display"
edit:Also Windows is only able to display in 16bit.
Reply 6 of 49, by sprcorreia
Are you running them in a dos box? If so, you must go to Display Properties and change color depth to 256 colors. It's probably set to 16 bit or more...
So, 16 bit only... That's odd... Have you installed ATI drivers?
Reply 7 of 49, by dosquest
No, I am running them on a windows95 computer non virtual machine running the above specs. When I try to adjust the windows display settings it says that my display driver is improperly configured.
Edit: I have not installed any drivers yet the drivers that are running are only the default auto detect drivers that are installed upon install of windows.
Reply 8 of 49, by sprcorreia
Well, no drivers for W95... But maybe win98 works.
Try these:
http://support.amd.com/us/gpudownload/Pages/legacy-98me.aspx
I think a still have old win95 ATI drivers CD's around here, not sure if they work with Rage Pro...
Reply 9 of 49, by dosquest
The machine probably had win98 originally when I got it it had no hdd, also the computer says that it is built for win98.
Reply 10 of 49, by dosquest
But, win95 doesn't support usb support and the file is over 2mb (way over) and this computer isn't configured for internet yet.
Reply 11 of 49, by sprcorreia
Simple. Burn the drivers to a cd...
Reply 12 of 49, by dosquest
Oh, well I'll burn it to a re-writable disc and see if it works. I'll probablly do it later I'm kinda busy. 😁
Reply 13 of 49, by dosquest
But as for driver compatibility do win98 drivers work on win95?
Reply 14 of 49, by sprcorreia
It usually works the other way around. Just give it a try.
Reply 15 of 49, by dosquest
Okay, I hope it works because I only have win95 install discs laying around (along with vista and xp but those wont help me right now.)
Reply 16 of 49, by dosquest
Wait, I forgot to mention that this card is onboard not pci slot. Will the driver still work for it?
Reply 17 of 49, by Davros
you could try dells website
Reply 18 of 49, by Tetrium
Ok, I decided to do a bit of googling and in the end came up with this:
http://support.gateway.com/support/drivers/se … =ati+rage&st=kw
It's the gateway site and appears to have the 95 drivers for the rage pro, amongst other drivers like the mach64.
Think this will work??
My retro rigs (old topic)
Report spammers here!
Reply 19 of 49, by dosquest
I'll try that, thanks. Oh, also I'll update you on the progress.
