First post, by wilhitewarrior
So I mounted my hard drive and my disc drive on DOSbox, ran the installation but when it does its tests, in testing the CD-rom drive speed it errors, I guess because my Blu-ray burner drive is far beyond anything that was even imagined at the time 🤣. But it wont let me install the game because of this and as far as I know, theres no way to bypass it on the install. Anyone have any recommendations for what to do? Thanks 😁
Reply 1 of 12, by leileilol
You could try typing 'cycles max' and 'core dynamic' before you start the installer if that helps.
On an actual DVD drive the test seems to pass for me. Also, are you using DOSBox 0.74? It was only recently that this game started working without a lengthy workaround.
Reply 2 of 12, by wilhitewarrior
Nope, no luck with that 🙁
Reply 3 of 12, by Gamecollector
Well, it PASS the check in 0.74 for me... 30-40 seconds to check. Cycles=20000, core=auto.
Then I check X-Com: Apocalypse because same dos installer was used for it. Again - 30-40 seconds and the check is passed.
Reply 4 of 12, by wilhitewarrior
Hum... maybe its a problem with my bluray drive then... Everything else seems to work okay but I also bypass the checks most of the time, unfortunately this game wont let me.
Oh and I'm running on windows 7, DOSbox v 0.74 btw... the CD-rom drive itself... I dont really remember its specs other than that its a blu-ray burner
Reply 6 of 12, by wilhitewarrior
Mount c c:\
Mount d d:\
I also tried installing it on my laptop, it only has a DVD drive, I had the same problem there too
Reply 7 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
please read a guide on how to use dosbox or type "intro"
You need a more complicated mount line for the cdrom.
Water flows down the stream
Reply 8 of 12, by wilhitewarrior
Yay! it worked!
I used the mount line
mount d d:\ -t cdrom -label STARTREK
and it worked... for some reason it wouldnt work without the label thing and I'm kinda a noob to this program, I dont really understand the -t thing 🤣 but thank you very much to all of you for your help and Im sorry to have troubled you
EDIT: Oh... -t... type. I'm an idiot
Reply 9 of 12, by Shagittarius
Its a bad idea mounting the root of your C drive as C: in Dosbox, I would change that if I were you. Your going to run into more problems in the future if you continue to use it this way.
Reply 10 of 12, by wilhitewarrior
I saw that it always says that but I never really understood why... but if it causes trouble I'll make a folder for my DOSbox stuff
Reply 11 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox will be slightly faster and it will be more secure.
Reply 12 of 12, by wilhitewarrior
Oh I see. Well speed has never been a problem for me, I've got a pretty beefy system but I'll do it anyway, thanks for all your help and sorry to have been a pest
