First post, by KiwiStalk
Hello dosbox wizards! I am having an odd problem with the 1993 Space Hulk game that I can't figure out, and I couldn't find any info on the forums to help out.
I got the package from Abandonia, and I'm running doxbox 0.74. The only non default setting I have is output = ddraw, res = 1920x1080 with fullscreen, and dynamic core.
I can run the game fine, but at the intro when the Warhammer 40k logo shows itself doxbox freezes with a "DMA segbound read" error. If I skip that screen it will run the game's intro until the last part when the space marines start shooting the genestealers, and it freezes with the same error. If I skip all the intros the game runs fine until the 2nd tutorial mission when I reach the end, when it again freezes with the same issue.
I'm guessing it's a sound driver/file issue. I've changed different things with the sound from type to dma settings. Basically, if I choose a device or setting that doesn't run PCM files but runs background music dosbox will still freeze in the same spots, and if I disable sound entirely the actual game with freeze in different spots.
Odd no? Any ideas?
Reply 1 of 1, by eL_PuSHeR
Go ask at Abandonia forums. We don't support abandonware here.
[THREAD LOCKED]
