First post, by ratfink
I put a wildcat vp760 in a ga5ax [decided to rebuild my k6/3+ system].
VP760 is a universal AGP card so it boots up, goes into windows 98. But after a few minutes the screen turns to garbage and the system seems to reboot, but all I see is different kinds of garbage. Garbage as in a screen full of coloured blocks, flashing. Never get far enough to get the drivers across the network. The card works fine in say an athlon board.
Is this just the crappiness of early AGP implementations not being good enough for the card? Insufficient power? What do you reckon? It's not simply overheating as it did this even with the case off.
