First post, by jim78b
i have a 1084s CGa monitor with video in db9 how i can coonect my pc to' it?
Reply 1 of 16, by shock__
The commodore 1084S is an ordinary 50hz RGB monitor with composite video.
Reply 2 of 16, by jim78b
and so...i will buy adapter?make a cable?
Reply 3 of 16, by leileilol
Forget it. Modern PCs won't ever output 640x200x1/320x200x2 required for it anyway. (The CGA monitor that is)
Reply 4 of 16, by 5u3
You would need a CGA card. The problem is, many CGAs do not fit into 16-bit ISA slots because of the shape of the board.
Reply 5 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
TV-out 😉
1+1=10
Reply 6 of 16, by jim78b
there is vga to' rgb CGa converter.the s video signal is disturbed can i have a one better?
Reply 7 of 16, by Anonymous Coward
You could try an ATi Graphics Solution Plus. These are 100% compatible CGA clones, and are quite sort in length, so there is no "skirt" that prevents installation in a 16-bit ISA slot.
Reply 8 of 16, by Markk
Why don't you use that monitor with your euro pc, which has cga card?
Reply 9 of 16, by jim78b
because euro pc is too old , in a modern pc desktop i will use dosbox with my cga monitor....understand?
the vga to cga adpter will be ok, but a question ,it has a rgb cable with 5 pin i will make a cable for it.....5pin to db9 is only problem....
http://www.arcadespareparts.com/arcade_parts/ … rter/12215.html
Reply 10 of 16, by Markk
But I think dosbox has a cga option, doesn't it?
Reply 11 of 16, by jim78b
yes but it is the same of the original cga monitor? what do you think about?!
Reply 12 of 16, by Markk
Well, in my opinion, if you have a vga card/monitor, there is no such a great difference, as it is compatible with ega/cga modes. I wouldn't mind using dosbox also. I don't think you're missing much compared to the original cga monitor, and certainly it would be less harm to your eyes.
Reply 13 of 16, by keropi
I am pretty sure that this is impossible ...
Reply 14 of 16, by DonutKing
Your best bet might be to ask on an arcade/MAME forum about the CGA adapter. A lot of old arcade machines used some variant of CGA and some people build MAME cabinets with CGA monitors in them.
One thing I noted with that adapter you linked:
Output CGA Signal: 480i@60 Hz
I didn't think this was a valid video mode for the type of CGA used in PC's? I thought that only 320x200 or 640x200 were used. Will your monitor handle this video mode?
Reply 15 of 16, by jim78b
ok now i will see how dosbox emu cga mode, if i don't satisfed i buy a arcade vga, or i see a real pci cga card, but window xp support two video cards?
ps another more less expensive solution is use software, powerstrip or soft15khz..!
Reply 16 of 16, by DonutKing
Yes windows XP does indeed support dual monitor output on two different video cards. As far as I know, you can't use onboard graphics on your motherboard and another video card; you need two seperate video cards.
As for a PCI CGA card, I very much doubt such a thing exists, CGA was obsolete before PCI came about, a quick google didn't show anything. The only CGA cards you'd find would be ISA or maybe MCA I'd imagine.
